Glen's 95 series Prado getting broken in
Last edited by glen_ep; 01-04-2020, 02:42 PM.glen_ep - engineered, 4" lift, 33" 255/85R16, lockers, 4.88 ratios www.pradopoint.com.au/showthread.php?17237 www.youtube.com/user/glenep www.fb.com/groups/ToyotaPrado90
Last edited by glen_ep; 01-04-2020, 02:39 PM.glen_ep - engineered, 4" lift, 33" 255/85R16, lockers, 4.88 ratios www.pradopoint.com.au/showthread.php?17237 www.youtube.com/user/glenep www.fb.com/groups/ToyotaPrado90
Glen you would make an excellent mechanic specialising in 4wd modificationsCheers,
Glenn
2002 GXL 3.4 auto with BFG AT's, Lovell's/Bilstein suspension, ARB steel bullbar, winch, towbar, diff lock, air compressor, GME UHF & AM CB radios.
[url=http://www.youtube.com/user/gh4wd?feature=mhum][b]Youtube[/b][/url] [url=http://www.panoramio.com/user/2941589][b]Panoramio[/b][/url]
Originally posted by GH4wd View PostGlen you would make an excellent mechanic specialising in 4wd modificationsglen_ep - engineered, 4" lift, 33" 255/85R16, lockers, 4.88 ratios www.pradopoint.com.au/showthread.php?17237 www.youtube.com/user/glenep www.fb.com/groups/ToyotaPrado90
Originally posted by Talktheroo View PostNice job Glen. That upper control arm looks very similar to the Hilux one. With the front wheel bearings what brand did you use? That upper ball joint is something else. You now have eliminated the problem with the hole routing out on the upper genuine control arms. That upper ball joint can be a real bastard to get out of the upper control arm. Affectively, you now have the same design as the 120s and the 150s except better. There's a lot of camber adjustment there now, wow. Did the new upper control arms come bushed or did you have to buy them separate? You weren't temptured to replace the bottom ball joint as well? Time for a wheel alignment ah, Glen.
To do with your driveshaft angles, that's about right. You could go a bit more, but that's pretty good.
Very interesting, can I ask you how much it cost you all up? John (##########).
I've never heard of the "hole routing out" issue... ? But yes it's a major pain to remove from the ball joint from the upper arm, I had a go, but as anticipated, handed it over to the pros
The UCA's came in black as you see them, ordered from USA, Fat Bob's Garage, Utah (home of Moab!!) for a price that can't be advertised. A single ball joint replacement would have cost $200, but instead this upgrade cost me a total $800 (UCA's, pressing labour, alignment).glen_ep - engineered, 4" lift, 33" 255/85R16, lockers, 4.88 ratios www.pradopoint.com.au/showthread.php?17237 www.youtube.com/user/glenep www.fb.com/groups/ToyotaPrado90
Hey Glen!!
Very good posts.
Any differences, feelings, etc in normal driving with the new UCAs?
7,6 and 9,4!!!!! That's a great difference in travel without the front sway bar with the new LR UCAs.
I like the LR UCAs because they came sealed. The other brands are very expensive, take more maintenance and become noisy from what I've read before.Prado RZJ90. OME 881 coils Nitrocharger Sport shocks front, 80 Series front coils & rear 80 series Tokico shocks rear, 255/85R16 Cooper Discoverer ST, Viper rocksliders, parking brake cable rear axle bracket, extended rear brake line, extended diff breathers, headers, engine perfomance mods, soon LR upper control arms, ARB rear locker in the future.
Originally posted by MDST View PostHey Glen!!
Very good posts.
Unfortunately I didn't test my old UCA with the sway bar removed, so I don't know if the 7.6" - 9.4" is any better than before. I would suspect it is though, because when parked flat, the new UCA is sitting higher than the old one, so it'd certainly allow more droop (assuming the shock and sway bar will allow it).glen_ep - engineered, 4" lift, 33" 255/85R16, lockers, 4.88 ratios www.pradopoint.com.au/showthread.php?17237 www.youtube.com/user/glenep www.fb.com/groups/ToyotaPrado90
Last edited by glen_ep; 01-04-2020, 11:45 PM.glen_ep - engineered, 4" lift, 33" 255/85R16, lockers, 4.88 ratios www.pradopoint.com.au/showthread.php?17237 www.youtube.com/user/glenep www.fb.com/groups/ToyotaPrado90
hey I was reading about your cv shaft problem I had problems with an after market shaft braking up the inner housing which I think happened due to it not having the same travel as a genuine shaft. I am now in the process of sorting out a Sonoran steel diff drop kit which I have been eyeing off for a while!75 Series Cruiser No More
Replaced with a G6E Turbo
95 Series Prado [url]http://www.pradopoint.com/showthread.php?19936-Beast2h-s-Prado[/url]
Hey beast2h,
I'm now running Repco ones which come with a waranty. I've noticed their shaft is noticably thicker, so here's hoping the cv joints are stronger too.
A diff drop is a great idea.. but bare in mind the bash plate may need some mods or spacing out (it's worth it though).Last edited by glen_ep; 26-05-2012, 11:53 PM.glen_ep - engineered, 4" lift, 33" 255/85R16, lockers, 4.88 ratios www.pradopoint.com.au/showthread.php?17237 www.youtube.com/user/glenep www.fb.com/groups/ToyotaPrado90
