MANNELL MOTORS 150 KAKADU
  • #31
    G'day Giles. Do you guys do under body protection for the 150? I have a TJM sump guard but it doesn't fit the petrol 150 so im trying to find an alternative.
    Cheers, Sam.
    • #32
      Re: MANNELL MOTORS 150 KAKADU
      Originally posted by William
      Hi Giles, as per my build up thread, I was wondering how many days it would take Mannel Motors to fit an ARB Sahara bar, OME suspension, ARB Compressor and rear air locker.
      Hey William,
      We would require the 150 for two days, We like to get things right the first time round.
      • #33
        Cheers, Sam.
        Hey Sam,
        Brown Davis make one which fits both Petrol and Diesel.
        It protects Radiator,Intercooler,Sump Diff and Steering. It also has Oil drain access as well.
        They are $451 (plus freight) but because your In Victoria you are best calling them and maybe popping in to grab one.
        By far the the best bet for the 150 ATM.
        For everyone in sydney i can get these easily.
        Hope this helps
        Giles
        • #34
          Hey William,
          You guys don't by any chance have a shop in Victoria do you? The shop I've taken my 150 to want 5 days to work on it :shock: The reason they gave was in case things don't go right the first time round. A real confidence booster there
          • #35
            Hey William,
            No not a big confidence booster at all. In the end regardless everyone makes mistakes and none of us a bullet proof... Its how you deal with the problem that is the main thing.
            A good end product is so important.
            • #36
              Cheers, Sam.
              Hey Sam,
              Hope this helps
              Giles
              Many thanks Giles. I'll give them
              a call.
              Cheers, Sam.
              • #37
                Cheers, Sam.
                Hey Sam,
                Hope this helps
                Giles
                a call.
                Cheers, Sam.
                Not a problem anytime
                • #38
                  Humex exhaust is coming soon... we will get some pics up ASAP! We cant wait to get the Kakadu breathing better! :P
                  • #39
                    Humex exhaust arrives TODAY! we can't wait to get it on...
                    • #40
                      Awesome Giles, can't wait for pics and a review. I was wondering if you could take a couple pics of the front recovery points for us too?
                      • #41
                        Our 3" Exhaust is bolt on, no cutting or welding.
                        New verses old dump pipe and engine pipe
                        New verses old centre muffler
                        Old verses new tail pipes
                        Dump pipe installed with thread for Pyro if required
                        Engine pipe and flexible joint installed
                        Centre muffler lines up well with the heat shield
                        And finished !!!
                        Goes great and these are available NOW !
                        • #42
                          exhaust looks good, how much drive in and drive away. cheers samo
                          • #43
                            Hey Samo,
                            $1275 + $250 Fit
                            All Prado Point Members $1475 fitted, And they are in stock now!
                            • #44
                              Hi Giles,
                              I am sure the pics of your rig will inspire yet more of us to part with the hard earned and imitate the Kakadu's build!
                              I have a two part question.
                              First, as I too have the Steinbauer module, some more details of the Humex exhaust would be welcome. Such as power/torque increase, driveability, NOISE, and whether the Steinbauer needs to be tweaked to optimise results.
                              Second, your under seat mounted compressor.
                              What is it bolted to?
                              I imagine the airline to front diff, plus wiring harness, must run along the centre console, then through firewall at front of dash passenger side?
                              For those considering F & R lockers, is this still feasible? Seems to run counter to accepted ARB practice. Would be nice to keep the compressor away from the under bonnet crud.
                              Greg.
                              • #45
                                Hey Greg,
                                1) The Steinbauer can be tweaked to suit the exhaust which is not a problem.
                                Not really much more info i can provide at the moment on the exhaust,i don't have the exact spec sheets yet but why what we can feel it's
                                made a big difference.
                                2) The ARB compressor is Bolted to the Floor
                                The Air Line goes through the floor via a gromet
                                The harness runs to the kick panel,along the trim where the door is,up and through the dash into the engine bay!
                                Hope this helps.
                                Giles
