ages 150 VX D4D black
  • #46
    Wow...... Way out of left field!
    Did not see any whisper of this on the forum, looks great.
    Can I see a spacer on the front upper suspension arm? Can you provide some details of the kit used?
    Any other adjustments needed at the rear end because of the level of lift? adjustable panhard rod?
    With some meaty high profile mud tyres its going to look sweeeet.
    Bernie
    • #47
      Hi Bernie,
      the details on the kit are as follows (this is pretty much straight from Matt at MR email). Also the Shock the MR uses are their own brand made for them with thier own specs.
      Adjustable height front coilovers
      long travel rear shocks
      diff relocation brackets for the front
      Upper control arms with 20mm extended ball joint
      and the kit for the non KDSS has swaybar relocators aswell.
      while they were experimenting with springs in the rear, cam reckons he had the back up around 4" and it was quite happy, but so i can have it engineered i need max of 3", so we had to drop it back to three.
      wheels are going to be Dick cepek torque on 265/70r17 MT muddies. cant wait!
      MR are also going to be making bash plates to suit the dropped diff at the font and one for the rear apparently. should be good to see
      150 VX diesel. Awesome bonnet protector! Monster Rides 3" Susp Lift, 265/70/17 MT MTZ's on Dick Cepek Torques, TJM T13 bar,TG150 Guard, Airtec Snorkel, Lightforce HID's, GME TX3540, CKMTA12 compressor, redarc dual bats, Drawers, fridgy drop slide, Maxtrax, More to come... one day!
      • #48
        Wicked!!!
        I've been waiting for this for a long time, I spoke with Max at monster rides regarding the kit, should only be a few weeks on finalizing things and then I'll have it delivered and fitted. The results look bloody awesome, bet you're bloody stoked there mate
        SOLD!!! 2011 Prado GXL manual in silver
        ARB Winchbar, Lightforce HID's, 3" SS Manta exhaust, 3" Monster Rides suspension system, Tracklander roofrack, Ostrich wing awning, Kaymar dual wheel carrier, Gturbo stage two Grunter and reprogrammed ECU. Trackabout Dakar SV Extenda. Purchased 2017 Landcruiser 200 Altitude.
        • #49
          Originally posted by Ages View Post
          I had been look for a while for somebody to produce a 3" lift for a prado with KDSS, but it seemed all to hard for just about everybody. But thanks to Shamozzle on PP i got put onto Monster Rides who were only just getting a kit together to suit the 150's and were more than happy to have a crack at putting it on mine. The whole process was a bit of suck and see along the way, But Cam from Auto transmission r us in Balcatta certainly seems to know his stuff. Aparently there were a few issues with the KDSS but nothing too major. There is still a front diff drop bracket to go in the take some angle off the CV's. The one that was sent with the kit didn't quite fit properly so they are going for a redesign.
          any ways... some pics!
          BEFORE
          AFTER
          How much supplied ?
          [CENTER][B][U]Matt
          [/CENTER]
          [SIZE=2]
          [/SIZE][CENTER][SIZE=2]
          [/SIZE][/CENTER]
          • #50
            Originally posted by Matt - mr4x4 View Post
            How much supplied ?
            umm i think the kit on it's own was just under or around $3700 mark... not entirely sure because i paid for fitting aswell.
            although i didn't need the sway bar relocators and the rear springs were sourced over here. so actually probably closer to 4k.
            Ages
            • #51
              Looks sweet - but 4K is hard to chew.
              Good to see you still fit in the garage though!
              • #52
                Awesome mate...4k is up there but if your happy its all good. Us WA Boys need to get out one day.
                2010 Kakadu with all the usual stuff.... Build up thread below
                • #53
                  yeah i'm very happy. there is still a bit of adjustability in it, so i think i'll get it engineered once the wheels go on and then maybe try for a little bit more height.
                  • #54
                    So being one of the six people wordwide that doesn't seem to want to put a rack on their roof, I decided to pursue this road and try and gain an extra few inches in the garage for when the lift and new shoes finally go on. All the parts are avail from Toyota and was about $180 all up. Plus about $10 for thread locker.
                    Won't go into taking the rails off. That's already been well documented in other threads. But here are the clips. There is a little arrow on them that has to face towards the middle of the car. Otherwise the plastic clip doesn't line up with the rest of the rubber insert
                    I am here: http://maps.google.com/maps?ll=-33.322649,115.637375
                    is this a universal Toyota part? or can it fit for a 90 series too?
                    Prado 95 3.0D Turbo Auto Series 1997, 285/70/16 Bridgestones AT 694's on 16x8 rims
                    • #55
                      I'm not completey sure to be honest. i just told them what i was planning on doing and that i needed something to fill the gap, and they had an exploded parts diagram which they just picked all the part numbers off of.
                      • #56
                        Latest addition today.
                        Starting to look a bit more serious. I'll get some better pics later
                        • #57
                          Size, make and road noise report thanks boss....
                          • #58
                            They are a 265/70r17 mickeythompson MTZ on Dick Cepek Torques.
                            they make a bit of a whine at freeway speeds, but not more than i was expecting. Looks like fuel has gone up a bit aswell.
                            • #59
                              looks like a "man" Prado now...awesome work. What did the rim/tyre combo end up costing? if you don't mind me asking.
                              • #60
                                That looks very nice now mate. Love those wheels.
