Schniffs 2010 VX D4D
  • Schniffs 2010 VX D4D
    Hi all, well I thought it was about time I did a build up thread. I have owned the best since Feb 2010 and have done the Kimberley, Flinders Ranges, Vic high country and Robe beach run in that time. With the exception of the bullbar and snorkel I have fitted everything myself.
    The beast at the Bungles:
    On blue rag in the Vic high country:
    More pictures to come!
    Re: Schniffs 2010 VX D4D
    More Carling switches. One on the left is for driving lights, middle for air compressor and right for rear camera override. The decal for the spotties came off after I got armourall on it.
      Second battery with Pirahna controller behind the airbox. I run two cables off it: 4 gauge via a 150 amp fuse to the interior and 8 gauge to a fuse box for underbonnet accessories. Winch is powered by main battery.
        Awesome! Easily my new favorite buildup on this site. Thanks for sharing.
        Especially interested in the audio setup. Did the kenwood install go smoothly? Noticed some spacers on either side of the head unit, where did you get them? Also, was it easy to integrate the factory camera?
          Kenwood install was straightforward. Those spacers are made by AERPRO, they are the standard ones for the space left by the generic Toyota radio.
          The reversing camera requires a 7v power supply. I used a DC-DC converter from this mob: http://www.hummingbirdelectronics.com.au/supplies.html.
          Then you have to splice the + and - video input cables and solder it to a standard RCA plug. Not too hard at all. The head unit has its own power supply for the camera, but I found that it would experience voltage drop and not power the camera properly, so I bypassed it and used a relay connected to the reversing circuit and the DC converter.
            Thanks for that. Also forgot to ask... Do the steering wheel controls work with the kenwood?
            Looking forward to your tune it chip review.
              Whoa! Nice rig, packed with the all the goodies too! How is the aerial fixed to the winch bar as I cant see any visible brackets?
                Nice truck - makes me want to upgrade
                Babs
                2011 VX D4D
                  William, I have full steering wheel control by using a device called a SWI-JACK made by PAC-Audio.
                  Switched, the aerial is connected via the welded on tabs that are standard on ARB deluxe bars these days.
                    Nice one Schniff, i reckon your bank acount is a bit lighter after that fitout.
                    [b]Rob[/b]
                      It wasnt too bad really. Drawers, wheels, tyres, tyredog, amps, speakers, compressor, UHF, awning, Dual battery all carried over from previous vehicle, accumulated over 3 years.
                        Thank you again schniff.
                          Awsome stuff, Thanks for sharing.
                          I also have (an earlier) Kenwood unit. How did you get the Toyota Symbol on start up?
                          [color=#0040FF]Rob[/color]
                            Mate I honestly can't fully remember. I had to use the USB connecter and a usb stick with the picture on it in a certain format.
                            Google will be your friend, search for "Custom logo on startup Kenwood head unit". It will be on one of the yank car audio forums.
                            The procedure is different for different head units.
                              Looks great and i like that picture of the water crossing. Textbook.
