Hi guys just a quick one on the goldstream i have a fan sitting behind the 3 way on a auto switch that goes off the temp. I would like full controls can i take the wires of the auto temp swith and put them straight into an on off switch that i can control or do i need a relay or something
Wring question camper trailer
If i understand you correctly, you are wanting to replace the thermostat with a standard on/off switch?
That will work with a straight swap! Pull the two wires from the thermostat and put direct to the on/off switch.
Alternatively, wire an on/off switch in parallel with the thermostat and then you have a permanent on, but with the swtich is in the off position the fan will still work via the thermostat... Esentially giving you an "auto/manual" option.
No extra relays required.2014 D4D 150 GXL Automatic - CHARCOAL
