HID Camp Light
  • HID Camp Light
    We carry fluoro lights for camping on our trips and I have been unhappy for sometime with the brightness. So decided to build a HID camp light.
    Bought the following:
    - 1 x Heavy Duty work light (Super Cheap Auto)
    - 1 x Tent pole with easy twist i.e cam action (Max length 2m)
    - 1 x HID Ballast and 50w bulb
    Current draw is around 5amp and total cost $120. Yet to make a bracket for the Rhino roofrack to hold the tent pole in place.
    Test run with my golf buggy battery -15ah
    That’s bright…..
    You can undo the wire by removing the grommet (yellow) with say a “watch makers” screwdriver. Then you don’t have to cut the wires to get the adaptor through.
    Had to drill a hole to get the wires out and the back of the bulb was touching the inside. All sealed with “Skilaflex” and waterproofed.
    Another closeup pic
    Dustie
    Re: HID Camp Light
    tip idea dustie, bloody hell it throws some light, no need for fluros as you say, i reckon the 12v battery would be doing some grumbling in the morning, do you reckon you would get an onite say out of the light and fridge running of the same deep cycle battery say the light was on for 5 hours. cheers samo
      Re: HID Camp Light
      Samo,
      The HID consumes 5amp. Normally I run 2 x fluoro @ 2.5amp which would be the same in terms of power consumption. I run the fluoro's for approx 3 hours with the Fridge and its been so far so good. But I have to drive the car the next day to get the charge back. But since I started to use the Solar panel on a regular basis, haven't had the need to run/drive the car for too long. Compared to the fluoro the light output is like 20 times if not more. I'd be happy if I get 2.5 - 3 hours
      The work light I bought from Super Cheap is waterproof aswell (got a rubber seal inside). You could attach it as a reverse light, keep tailgaters away or run them off the road :mrgreen:
      Dustie
