I was just wondering if anyone else has had any problems with the remote handpiece for the TX3440?
I was doing the weekly chore of cleaning the interior and noticed that LCD screen in the handpiece was at an angle to the body. When i turned the unit on all worked well,but the problem also is that you can change the channel or adjust the volume but it does not change on the screen!
The next time that you turn it off and then on it will have changed to the correct channel.
Not very happy as we haven't been out anywhere to shake the ^%$#$% out of it! We only purchased it in Aug 08 so at least it is not that old maybe they will replace.
I have contacted GME and have been told that i have to send the whole unit to the warranty section in Sydney. Not that this is a problem but because the unit is located under console,This just means taking all out and then when renewed or repaired putting it all back again.
Would be interested to hear if this is a problem or a one off.
