Broken windscreen woes
  • Broken windscreen woes
    Took the brand new Landcruiser Workmate troopy out to Rawlinna for the Nullabor Muster this past weekend. The vehicle performed faultlessly and that sweet V8 t/dsl is a mighty worker, pulls like a train but just as happy to tootle around at not much more than idle speed.
    But, on the way back to Kalgoorlie, whilst passing some slower traffic I copped a stone to the windshield. Crack, nice big line right in line with your face and extending halfway across the screen.
    No worries, ring up and booked her in to get a new screen. Bring her straight in the guys says.
    When we get the truck in there the bloke says that because it's the "new" model - dual airbags, adjustable steering wheel, CD player, etc - it's going to be around 3 months until they can get screens into Australia!
    AARRGGHH!!
    Re: Broken windscreen woes
    Thats not good Dave hope you don,t get a yellow, 3 months without the work vehicle wouldn,t be good. :wink: . We are back home at the moment for the sons wedding then on the road again but probably go up the coast where the weather will be warmer, hope you had a good time when you were down in Perth. catch you Chris
    96 SWB, fire engine red, turbo,auto,
    50mm king springs, tough dog shocks,
    13mm strut spacer, 17 x8inch wheels incubus poltergeist 17x8
    265x70x17 Kelly TSR, factory sunroof,
    Dual batteries, gme 3220 uhf, turbo timer
    , ipf extreme spots, cibie super oscar spreads converted to HID.
    Factory alloy bar, Safari snorkel,
    Table on rear door, Rear work light
    300watt inverter, high lift jack
    Wish List (winch and front air locker)
      I would check around about this...something does not sound right unless all the ones they in country were used up in Perth? But I know from reading some place that a lot of the windscreens are made in Australia for the Toytotas and other models. I would do some calling around.
      Manata 3" Exhaust, Blisten shocks, King Springs 50 mm lift, Poly Air Bags, Roof Rack, Iron Man Bull Bar, HID 50W LightForce XGT spotties, Daul Batteries, GME TX3440 & AE4705 ant, Upgraded window washer, Bonnet Scoop, Tunit chip, bonnet protector, headlight protector, Cooper STT's, ScangaugeII, Dash Mat, Endless Air, Stebel Nautilus, Diff Breathers, Water Sedimentor. ([b]Camprite TL8s [/b] Arrived ALIVE~!)
        I replaced my windscreen about 3 weeks ago (a week before the hail storm) and couldn't get a genuine screen either.
        When I asked why...the bloke at Toyota said "because Aussies aren't stupid enough to pay $1080.00 + fitting for a new one". I wen't no s*&t!!
        Fitted and API glass for $350.00 fitted and tinted. It does have the typical heat/laminating waves of cheaper screens if you look through it sideways (Can't notice it looking forward), but hell for the price and the fact that the last one lasted 10 months I can't see why you would buy anything else.
        2009 GXL D4D White Auto - ARB Duluxe Bar - Lightforce 240 Blitz spots - Icom IC440 CB - Bilstein shocks, Lovells 1.5" lift H/Duty coils - Polyairs - Tracklander Alloy roof cage and ladder - Maxtrax - rear work lights - PP Rear-door-table - Underfloor water tank - 275/65/17 BFG AT's - Ranox dual battery system - Rear door spacer - Safari snorkel - Steel sliders - ARB front and rear air lockers - ARB CKMTA12 onboard air compressor...
          We might have some luck with Deans Auto glass as they reckon they have a secret stash!
          When you have to compete with the big mining companies you often get treated like a second class citizen.
            I work for one of those and we have been told 3 months as well....
            [color=red]GXL D4D AUTO Option pack more to follow & Camprite TL8s[/color] [url=http://www.fuelly.com/driver/Chuck1/prado][img]http://www.fuelly.com/smallsig-metric/46023.png[/img][/url]
            Diabolus fecit, ut id facerem!
              Was travelling in the NSW snowys in Feb and got a cracked windscreen on the Alpine Way from a motor bike going flat out , but when pulled up at some road works were they were resealing the road and got talking to the stop/go man. Told him what had just happened and he told me that if I had said it had happened as a result of the new road works I would just have to see the site manager and he would give me a chit for a new windscreen. So if you are driving along a new stretch of road and get a crack ring the local council and tell them and they will put you in touch with the mob that fixed the road for a replacement windscreen. I did not do this as the stop/go man was in fact the site manager ( bugger ) , But this is what he told me happens . Cheers Digger
              White GXL 150 TD , Black King Rims with BFG , 40 l Engal, Thumper power supply, Tracklander roof racks,Maxx Tracs , Icom ic440, Redex Brake Controller, Factory towbar, Sidewinder trailer charging system, Rock Tamer Mudflaps and Hema Navigator.Camprite TL8S
                Folks
                Here's another one that works if you have a cracked screen, find a concrete agitator truck from a major company, get the rego number, time and date ring the local branch and bingo new screen.
                Regards, Richo
                  Is the windscreen different on the 'update' V8 models. (ie: The V8's with the airbags, etc - Post mid 2009 from memory).
                  I've had to replace a couple of windscreens on my 70 series V8 (but the non airbag version - 2008 model), and it was exactly
                  the same windscreen as the previous 1985 onwards 75/78/79 etc models. Maybe it's now 'bonded' in place with urethane
                  like other more modern vehicles rather than held in with the rubber seals like all older versions.
                  Just an enquiring mind, as I haven't seen one of the update/airbag models up close to have a look..............
                  John
                  Ex 95 and 79 series owner, now FJ Cruiser owner.
