Folding boat rack
  • Folding boat rack
    After about 5 weekends work i have finished the first stage of my CT boat rack 2 days before we went up north :!:
    Ive just came back from Cape Range N.P near Exmouth and after mostly bitumen roads with a few rough tracks on the way its held up really well.
    Most of the time building it was taken stuffing around with the gas struts and thier still not the right pressure nor the right postion.(thier upside down)But its nothing that cant be sorted.Its the first time Ived played with gas struts and its sooooo friggin hard to work out thier postion and what size you need.
    Most of Its made from 50mm x 50mm x 2mm gal square tube and boy did the cold saw at work (so did the MIG) came in handy for the cuts .I made my own tie down points out of 10mm S/steel rod.I purchace these over centre catches(as seen in the first picture)from Ovesco.
    Im going to make some extra storage in the gap between the CT cover and the bottom of the rack for things like a second spare and maybe the outboard motor.
    Its also over 750kgs (now its 910kgs) so I need to fit some trailer brakes :roll:
    White 2003 V6 GXL, 4spd auto, Vapor injected LPG, Autocraft Prem Billstein 2inch lift with poly air-bags
    Re: Folding boat rack
    cannot view photos
    Winston.
      Hi winniliss
      Thanks for letting me know. Is anyone else having the same problem (as I can see the pics fine in the post)?
        No I can not see the images either.
        [COLOR=#000080]Nick[/COLOR]
          When I set up the struts on my camper for the lift up top section I got the struts from Martins trailers. On their website under a section called Pamphlets there is a guide to working out the Newton size of the strut and its mountings. I needed over 160 kg of "lift" to raise the tent section to clear my motorbikes.
          Check out their site [url][http://www.trailerparts.net.au//url]
          Wayne
            Originally posted by Billy
            Hi winniliss
            piccys not showing either, would be great to see
            2010 Blue Storm GXL Deisel Auto, HR towbar, uniden UHF, 270/65/17 BFG A/T, Delux ARB bullbar (FITTED), IPF Xtreme Spotties, Safari Snorkel (to come) Sungrabba mats (awesome)
              Not seeing photo at work or at home :cry:
              Manata 3" Exhaust, Blisten shocks, King Springs 50 mm lift, Poly Air Bags, Roof Rack, Iron Man Bull Bar, HID 50W LightForce XGT spotties, Daul Batteries, GME TX3440 & AE4705 ant, Upgraded window washer, Bonnet Scoop, Tunit chip, bonnet protector, headlight protector, Cooper STT's, ScangaugeII, Dash Mat, Endless Air, Stebel Nautilus, Diff Breathers, Water Sedimentor. ([b]Camprite TL8s [/b] Arrived ALIVE~!)
                I can't see the pics either but recreated the post using the embedded URL in the original photos in Billy's post.
                  ah Cheers amts for taking the time to do that - I couldn't work out where I had gone wrong as I (thought I had) followed all the 'structions.
                  (usually download from my wife's Gallery but that's down atm so signed up for postimage - first time using it)
                  Thanks!
                    Thats better
                    Winston.
