Willowglen Challenge 2013
Yeah mate I'm planning to go down for a day. Hope to see you there
The rig is very clean!! Did you have to remove the spotties for the comp?glen_ep - engineered, 4" lift, 33" 255/85R16, lockers, 4.88 ratios www.pradopoint.com.au/showthread.php?17237 www.youtube.com/user/glenep www.fb.com/groups/ToyotaPrado90
Ill be there as part of the recovery teams. If you see a Graphite 150 with ALI194 plates, that will be me.My Rig: 150 GXL D4D, Tough Dog adjustable suspension with 60mm lift, Polyair bags, ARB Winch Bar, Warn Winch with Dynamica Rope, Outback Ideas recovery points, GME UHF, HID Low/High Beam, Lightforce Genesis HID Spots, Dual Battery Setup with rear power outlets, ARB air compressor in engine bay, ~30L Watertank mounted behind fueltank.
No got defected earlier this year and had to change the front bar so it went backwardsOriginally posted by glen_ep View PostYeah mate I'm planning to go down for a day. Hope to see you there
Also I have painted the car so it looks a lot better now...If its not on all 4's it's not on.....
2008 GXL D4D, OME lift, arb bar, IPF 55W HIDs, HID headlights, duel Batteries, Winch, UHF, Safari Snorkel, bfg km2's, arb side awning, rola cage, engel fridge, kaymar rear bar(to fit)
No probs say hello when I come across the track u are onOriginally posted by Ryzz View PostIll be there as part of the recovery teams. If you see a Graphite 150 with ALI194 plates, that will be me.
I hope I don't Need recovering too much lol...If its not on all 4's it's not on.....
Dont worry, ive heard there is a new barter system in place for recoveries this year. A snatch is worth a 6 pack, right upto a roll over is worth a caseOriginally posted by mudboy View PostNo probs say hello when I come across the track u are on
Will say hello regardless though
RyanMy Rig: 150 GXL D4D, Tough Dog adjustable suspension with 60mm lift, Polyair bags, ARB Winch Bar, Warn Winch with Dynamica Rope, Outback Ideas recovery points, GME UHF, HID Low/High Beam, Lightforce Genesis HID Spots, Dual Battery Setup with rear power outlets, ARB air compressor in engine bay, ~30L Watertank mounted behind fueltank.
