ARB/TJM air compressor & fuel filter bracket for 120/150
  • With the ARB compressor in the engine bay how to people find it to be heating up and hitting the thermal cut-off?
    • Had mine in for about two years now and used it about 5-8 times. It has never cut off because of heat. A key thing to keep in mind it is to keep the engine running while using compressor.
      2010 Prado 150 GXL Diesel, Cooper AT3, ARB compressor, Catch Can, Redarc BCDC 1225, Projecta DBC150, Optima YellowTop and RedTop D34, Pioneer Backbone Platform
      • Originally posted by mullerwh View Post
        Yeah I make sure to do that. If it gets run with the engine off it's easy to hear the difference in performance. The only time it hit the thermal cut was after a long day of driving and on the 6th tyre going from 20 up to 40 PSI
        • Getting ready to pull the trigger on amts MKII bracket but need to check a couple of quick questions.
          1. With a Racor 230T filter is it necessary to file down the bottom valve to make it possible to open and close it?
          2. With a CKMA12 are the 2 spare outlets still accessible for future airlocker use?
          3. With a Racor 230T i understand it needs to be removed to replace the filter?
          4. A few years on, has there been and failures that would be attributed to excess heat due to the cramped install position?
          Lastly amts, whats the lead time on a MKII compatible with racor filter + switch bracket?
          Check out our blog documenting our around Australia adventure: [URL="http://fealyfamily.wordpress.com/"]http://fealyfamily.wordpress.com/[/URL] 07 GXL D4D, Bilstein shocks, Dobinson coils, Red Arc isolator, 105Ah Allrounder dual battery, heavy duty outlet in rear for the CF80 Waeco. Tigerz11 full size rack and awning. GME TX 3100 UHF, Alpine CDE135bt head unit with Steering Wheel controller. Hilux washer jets. Zac Brown Band sticker
          • Originally posted by myminirocks View Post
            No longer needed. Bracket has been modified to be mounted higher
            Yes
            Yes
            Not that I know off
            Currently available
            • Thanks amts. leave it with me.
              • 2 1/2 years later and I'm finally putting this in
                A couple of questions...
                * Are there written instructions that I can give my mechanic.. (still time/skill poor so it's off to the mechanic)
                * Which water separator fits best with the bracket... (mkII ordered and received Dec 2013)
                I noticed someone mentioned filing off something... is this the bracket I would have?
                Cheers, Leon
                Optix Photographix
                • Originally posted by Snaga View Post
                  The installation instructions can be downloaded from here https://app.box.com/s/pfd9ag7ozdc8jzfd042k
                  I'll need a pic of the bracket to be sure. Racor 230R will definitely fit. The FM100 requires an additional bkt on the original MK2 but will now fit without an additional bkt on the revised version.
                    Thanks for the download... I thought there was but have a new computer since then and couldn't find your email.
                    Is one filter better than the other? I haven't bought anything yet so happy to go with what fits easier if no difference in performance that you know of.
                    Cheers, Leon
                    Optix Photographix
                      Sorry, I didn't go too much into which one is better as I own the V6. For a start, the filter needs to meet the minimum flow rate and should filter down to whatever micron level it claims to filter. The FM100 is longer so depending on which Mk2 bkt you have, you may or may not be able to fit that model.
ID:	653270Click image for larger version
                        Cheers, Leon
                        Optix Photographix
                          [ATTACH=CONFIG]22785[/ATTACH][ATTACH=CONFIG]22786[/ATTACH]
                          That will fit the Racor only.
                            Sweet, thanks amts
                            Cheers, Leon
                            Optix Photographix
                            • Sorry Amts... last Q, I think...
                              Is the Racor 230R still the one that fits?
                              Cheers, Leon
                              Optix Photographix
                                Yes, correct.
