Originally posted by AJ120
View Post
ARB/TJM air compressor & fuel filter bracket for 120/150
Originally posted by Octane94 View PostHi mate,
by where the second battery goes im guessing you mean behind drivers headlight, i just used a piranha battery tray for the 120 and mounted a compressor that way.
Mounting an ARB compressor behind the headlight is about as easy as it gets!
Leave a comment:
Guest repliedBut battery trays are $$$$
Leave a comment:
Leave a comment:
Originally posted by Jeffers View PostI would also be interested in having the compressor located where the second battery would be.
Are you still considering this AMTS?
Jeff
by where the second battery goes im guessing you mean behind drivers headlight, i just used a piranha battery tray for the 120 and mounted a compressor that way.Last edited by Octane94; 07-03-2013, 09:49 PM.
Leave a comment:
Guest repliedOriginally posted by thebigo View PostMy question is can these compressors be hidden somewhere else in the front of the 120 Prados or is where you are all looking the best spot?
Happy to work on the second battery location too if someone would assist with some dimensions.
Meanwhile, I've picked up the brackets from the fabricator today. Need to check them and then off to the welders.
Leave a comment:
Originally posted by amts View PostNo problems John. I'm up to Plan D already for fitting the filter and air compressor in the same location. ;-)
Jeff
Leave a comment:
Starting to think about fitting a compressor and this kind of effort to produce a good custom option is awesome.
Do have one question. My mate just got an arb compressor fitted to his 09 pajero and they fitted it down behind the front headlight with an outlet in front of the radiator. Bloody good install and I didn't know he had a compressor till he showed me it hidden. My question is can these compressors be hidden somewhere else in the front of the 120 Prados or is where you are all looking the best spot?
By the way his was pretty good for noise when in the cab considering it is down near the headlight away from the cab.
Leave a comment:
Guest repliedThank you John. Working on it.
Leave a comment:
Guest repliedThanks John. I'll try my best.
I can't use that Parker link as it is asking me to login.Last edited by amts; 05-03-2013, 11:11 AM.
Leave a comment:
Guest repliedMick, Michael, Dave,
You're on the list.
Leave a comment:
Guest repliedNo problems John. I'm up to Plan D already for fitting the filter and air compressor in the same location. ;-)
Leave a comment:
Guest
Guest
Guest
Guest
Guest
Guest
Leave a comment:
