Drifta rear drawers and Cargo Barrier for 120 Prado
  • Drifta rear drawers and Cargo Barrier for 120 Prado
    Item: Drifta rear drawers to suit 120 Prado
    CARGO BARRIER SOLD
    Condition: Excellent
    Reason for Selling: changing vehicles
    Price & Price Conditions: $1100 neg
    Extra Info: Complete with turnbuckles, side wings, pullout table, insert drawer
    Check out Drifta's website for more info.
    These drawers offer significant weight savings over steel drawers with the added advantage of more space due to the fact there are no roller bearings.
    The drawers slide beautifully on Teflon runners.
    Dimensions 945 long x 1055 wide x 285 high
    Am able to deliver around Brisbane if required
    Photos: Click image for larger version
    thawifestrolley
    Lurker
    Last edited by thawifestrolley; 07-08-2016, 02:03 PM. Reason: cargo barrier is sold
    2016 GXL, AFN Bullbar, Runva 11XP winch, Ironman Foam Cell Pro suspension, Ironman underbody protection and sidesteps, TJM snorkel, Icom IC 450 UHF, Ironman lightbar, drifta drawers, Rhinorack backbone with Pioneer platform
    Trolley
    Just wondering if the right side drawer (facing the drawers) can be replaced with a car kitchen box?
    Thx
    Pierre
      Originally posted by Auscanclan View Post
      Trolley
      Thx
      Pierre
      They can if the drawer height and length hasn't been customised. They are usually a straight swap for the car back kitchen, unless you've had the drifta slide out fridge slide fitted (speaking from experience). Just get the measurements from the seller and confirm with Drifta (they can customise you one if needed). I wouldn't recommend getting the car back kitchen with the rear drawers. They do one designed to fit the 4wd drawers that is one long drawer which is what I had. Otherwise you have to pull the whole kitchen out to access the contents of the drawers
        Hi canclan
        The drawers haven't been modified in any way.
        I did have the MSA drop slide installed with the captive nuts but I don't know for sure if what you are asking is possible.
        As above, check with Drifta and if you need any further info just let me know.
        BTW I'm just about to edit the ad as I've just sold the cargo barrier
          The SD-DCB model car back kitchen is the one I was referring to. Probably won't fit:
          Standard dimensions:
          Height: 300 mm
          Length: 900 mm
          Width: 480 mm
          Weight: 20 kgs.
          The Carback (DCB) might:
          Height: 290mm
          Length: 900 mm
          Width: 480 mm
          Drifta could easily make one or the other (Drawers or kitchen) to match... It would be easier to get them to make the Carback to match the drawers, and cheaper for you (unless you already have a kitchen)
            Hi thewifestrolley are the drawers still available if so would like to have a look, ph 0458417106
              yes, They are still available.
              I've just sent you a text
                This item has now sold
