I've run out of the 120ABHDs. They are about 8 weeks away.
120 Grande rear airbag to coil conversion (AMTS coils)
Hi Akmbell, do you mean the Metal Tech kit is able to enable the rear suspension lift with removing the airbag?Originally posted by [email protected]If you get a 2 inch lift and attempt to use the height control at full articulation, you WILL blow the airbags and land on the stops.... its a long way back home - done it 3 times. Tried airbagman for a 2 inch lift etc.... still no good. So basically if you are going to put a lift on a 120 grande and use the height control, it is likely you will pop them if you fully articulate the rear. I think I used the below but there may be others - there was no-one 2 years ago that did it here that i could find. Koni/Kings combo is awesome
https://www.metaltech4x4.com/metal-t...-toyota-parts/
- 1 like
Hey gang, just popped not 1 but 2 of my rear airbags on the wrong side of Murchison station, and had to drive back to Perth in the bump stops.
AMTS are you still selling the coil conversion springs still?I thought I would be differant and get a silver prado...
2004 Grande, 4lt petty, Sov front bar, 9000 Lb tigers winch, factory tow bar, Fwd Rec points, Safari Snorkel, Bushskinz bash plates, Austrack roof top tent on Steel RTT rack, Kings awning, ARB under bonnet compressor, Coleman on Demand HWS, IPad with retina on a Ram mount running Hema Navigator, GME TX 3400, Tekonsha P3 Brake controller, and a Stihl 181.
