ITEM:
Boab 40L Poly water tank for rear footwell
CONDITION:
Used for three (3) week Cape York Trip in June/July 2013
REASON FOR SELLING:
Need to clean garage out and next trip we have planned we'll be taking the camper trailer.
PRICE AND PRICE CONDITIONS:
$200 pick up including the tank and the fittings with short length of food grade hose. These fittings are high quality and not cheap plastic fittings. Included on each outlet is a metal tap and brass 90 degree elbow.
EXTRA INFO:
Part Number: WTP40FW
This poly tank is extremely strong and shaped to sit on the vehicle floor behind the front seats in cars and wagons. The cutout spans the transmission tunnel. The non slip top section can be used as a floor for children or for loading luggage etc.
The tank has an outlet each side to position a hose or a second hose can be used to allow an outlet each side. The tank is fitted with a high quality metal tap and brass 90 degree elbow with food grade hose attached.
Dimensions:
1200mm wide x 190mm high ( 30mm for cap) & 250mm Deep.
The transmission tunnel recess is 420mm wide at the base tapering to 200mm wide at top of recess, and is 110mm high.
The cut-out for centre consoles is 200mm wide and 60mm deep.
http://www.kulkyne.com/au/Footwell-Water-Tank-42L.html
https://www.4x4andmore.com.au/Shop-O...OOT-WELL-POLY-
PICTURES:
CONDITION:
REASON FOR SELLING:
EXTRA INFO:
Dimensions:
PICTURES:
