Just did an auto oil change and the plug thread feels shady and I didn't feel safe cranking it to 15ftpounds as it didn't seem to be nipping up very well. So next change, can I he'll coil it or do I need a new pan?
Is it possible to hellicoil auto sump plug?
Hey,
Both the drain plug and the overflow plug on the auto sump seal with a Toyota OEM crush washer. That washer may not fit a larger thread size.
Unless you can find a larger diameter crush washer to suit, it might be worth looking at a new sump, no point risking damage to the auto with an oil leak, too expensive to fix!
Mark2006 GXL petrol auto. ARB deluxe bar x3 HID IPF's, ARB alloy roofrack, ARB awning, BFG A/T, Safari snorkel, Piranha breathers, Pacemaker extractors, custom Ironman 45710FE 436-569mm with Dobinsons 350, custom Ironman 45682FE 383-618mm with Dobinsons 487, Firestone kevlar 60psi airbags, 30mm extended Roadsafe links, AMTS bashplate and recovery points, ABR Flyer with Powersonic AGM.
