Hi Guys
Couldn't find any other posts relating to this so here goes!
Bought:
http://www.ebay.com.au/itm/7-Toyota-...item3f1bcbcd32
and fitted it OK to my 10/2008 120GXL. Plug & Play as advertised.
But...I have a problem with the steering wheel controls trying to 'learn' the >>| button (the ^ on the steering wheel pad).
I'm unsure how other aftermarket head units work (maybe the following numbers don't mean anything) but on this one I enter the steering wheel learning mode & the first button is the Mode button which registers "16" when I press it. The next button is >>| and in pressing the ^ button on the wheel it goes straight back to the Mode command.
I've established that the ^ button also generates a "16" code, the same as the Mode button. All other buttons work fine. It appears that the Mode button and the ^ button on the steering wheel are outputting the same command, causing obvious confusion to the head unit.
I can't see that it is an issue with the head unit as it should record whatever button is pressed & I can't work out why the Mode & ^ buttons are sending the same signal. The Toyota standard head unit worked fine.
Does anyone have any similar experiences with other aftermarket head units or know of a fix?
Craig
Bought:
Craig
