go me chrissy present today, its a pearler. thanks santa
opensky awning pics
Samo,
Looks great mate. Just need to find some funds to buy it all. Just out of interest di you think that there is any way that the awning can be attached directly to the Prado factory roof bars (the ones that run down the side)Regards,
Big Fella
2007 Prado GXL D-4D Auto. Black. Cooper ATR's, ARB Bull Bar, Safari Snorkel, ARB Dual Battery, Sandgrabba Mats, Black Duck Seat Covers, Plastic Bits on the front, Mesh Grill Guard, Tinted Front Windows, Towbar, Reverse Sensors, Lightforce Blitz 240's, ORS Drawer System. ScanguageII, Stebel Truck Horn, Icom 440 UHF Radio and BIlstein/Ridepro Premium Lift Kit.
If you can't fix it with a hammer...... you have an electrical problem.
[img]http://img.photobucket.com/albums/v655/pradovx96/Web%20photos/emailsig.jpg[/img]
Hi Samo,
That is a great setup mate, you have been nice to Santa this year! how long does it take to fit/remove the Rhino Basket/Rack and Open Sky Awning as I am eyeing off a similar setup can't have for Chrissy as going to the Australian Tennis Open. Hmmm maybe birthday07 Upgrade GXL D4D, Manual, Dune,Sov Bar, BFG's, SG11, Redark dual Batts, Extensive Aux wiring, Stebel, LED stop tails, IPF HID's (my mod), 240V Inv, ARB Comp, GME UHF,TPMS, Safari snorkel, GPS,Hilux washers, 40l Engel in 30% pas pos,homemade A/C cond protection plate, polyairs.
the awning is just bolted through the plastic between the top and bottom rail, it takes 5 mins to remove, the basket and rails to remove as one take as much time as it does to undo 6 bolts, thats with 2 people to lift the whole thing off, by yourself it takes about 20 min to break it downhad an 03 gx 120 with some gear now got a 2013 bt 50 GT auto some ARB gear.
Thanks Samo,
It will be going on the list.07 Upgrade GXL D4D, Manual, Dune,Sov Bar, BFG's, SG11, Redark dual Batts, Extensive Aux wiring, Stebel, LED stop tails, IPF HID's (my mod), 240V Inv, ARB Comp, GME UHF,TPMS, Safari snorkel, GPS,Hilux washers, 40l Engel in 30% pas pos,homemade A/C cond protection plate, polyairs.
Samo, can you tell me what distance it is from the sidestep to the edge of the awning? Your photo makes it look a tad narrow, but photos can give a distorted view.
Have you taken a measure mate?
Also is that out as far as it will go?LES
[url=http://www.brisbane4wdclub.org/index1.htm]Brisbane 4Wd Club Inc[/url]
[url=http://www.brisbane4wdclub.org/images/avatars/mystuff.htm]MY STUFF[/url]
2.1 wide, minus 30 cm leaves about 1.8. The one I have is wider than that but does not compare in the length. Its 2.1 x 2.1 usable area, with no brace.
Thanks mate.LES
