I purchased a EWX 9500q competition winch
My 3rd use of it and it failed me half way up a hill climb. I was stuck and I was red going to be stranded so I had to get back down, scary I can tell u and I thought for sure it wasn't going to end well.
I made it back to the bottom and after my right cv pulled out the diff and losing my rear bar and flares,
I contacted Runva regarding this as the winch is still under warranty, I also removed the control box cover to find why it wasn't working. To my amazement the red a blue terminal leads are hard up against each other which eventually wore through and shorted out. As far as I'm concerned it's a manufacturer problem and there is no other way to have them in the box( btw I never connected that end as the control his was already done in the box new)
My reply from Runva is as follows
Adam,
Under basic winch maintenance in the manual it says to check all electrical connections regularly to make sure they are clean and tight.
You will need to replace the control box + wires which we are able to supply for $100.00 inc GST & delivery to help you out.
Absolutely load of bullshit
If some one can tell me how to upload photos I will gladly show the problem
If you buy a winch from them after reading this and u get stuck , u will only have yourself to blame
Adam,
