That's a Brilliant Price, I got a set a while ago through a mate "at cost" and paid $275, about 2months before BCF started selling them for $279. Either money very well spent I reckon.
Maxtrax
Big Dog
Updated my earlier post to embed the video...Cheers, Leon
Optix Photographix
I just got a catalogue for Supercheap this arvo, they have them on special as of tomorrow for $249 until 13/6Justin
2005 120 Series 3.0 TD Auto, OME suspension, Sovereign bullbar, IPF 900XS driving lights, Projecta dual battery system, ARB roof rack, Bridgestone D694 tyres, GME UHF, Custom rear drawer with ARB fridge slide and Waeco 60lt fridge.
Last edited by ondaboat; 01-06-2011, 08:56 PM.Yep.....I have a Prado just like you
Maxtrax on special at super cheap auto for $249 for twoD4D 2009, Auto, White, ARB Deluxe Bullbar, IPF 900XP driving lights, Red Arc & 2nd Battery, ARB compressor, Maxtrax, BFG AT's, Fourby Fitout drawer system, ARB 47ltr Fridge, GME UHF, ARB reversing camera mirror, SCA Sheepskin covers, 12/240v Inverter, ARB awning hanging from wire basket, 9000lb winch.
Picked mine up at super cheaps on the wekend. Then went out and tried my hardest to get stuck, and wouldn't ya know it. May as well left them at home.
Their time will come i'm sure...150 VX diesel. Awesome bonnet protector! Monster Rides 3" Susp Lift, 265/70/17 MT MTZ's on Dick Cepek Torques, TJM T13 bar,TG150 Guard, Airtec Snorkel, Lightforce HID's, GME TX3540, CKMTA12 compressor, redarc dual bats, Drawers, fridgy drop slide, Maxtrax, More to come... one day!
Heading down to the otways this weekend with the maxtrax on the roof. Should be able to find some mud somewhere!D4D 2009, Auto, White, ARB Deluxe Bullbar, IPF 900XP driving lights, Red Arc & 2nd Battery, ARB compressor, Maxtrax, BFG AT's, Fourby Fitout drawer system, ARB 47ltr Fridge, GME UHF, ARB reversing camera mirror, SCA Sheepskin covers, 12/240v Inverter, ARB awning hanging from wire basket, 9000lb winch.
Hi Chester
What type of roof rack bars do you have fitted.
I've got the Rhino/Toyota heavy duty bars. With these I think that you could use some flat bar and a plate nut to fashion a mounting bracket.
Cut the flat bar a little wider than the Maxtrax, mark and drill holes at the same centers as the Maxtrax mounting holes.
Drill hole in the center of flat bar to allow for plate nut bolt to clear.
could weld nuts to mounting holes on plate and use a longer bolt in one with a hole drilled through for a security padlock.
These plate nuts are available from your roof rack supplier or electrical wholesaler as (Unistrut nuts).
I have used M10 and M12 in the H/D bars but watch the bolt length can bottom out on the roof rack internal web.
Cheers TroySOUTH AUSTRALIA GATEWAY TO THE OUTBACK!
Originally posted by amts View PostA variation to Troy's flat bar design...
After attaching the flat bar across the HD roof racks, drill and tap M10 holes to match the holes in the Maxtrax. Then use a star knob to secure the Maxtrax. Drill through the thread of the star knob for a padlock
The company I work for uses Concept Fasteners. Currently waiting on pricing from them for both zinc plated and stainless steel.
Bunnings may have them but might not have the range. Farnell, RS and Blackwoods should have them although Farnell and RS are usually overpriced.
I reckon a 50mm long thread should be enough for 2 maxtraxs and a padlock (depending on how thick the flat bar is). I have some 10mm ally at home.
Seeing as a hole will be drilled into the spindle, it is probably best to get the stainless version.
Cheers Andrew. Stainless would be the go. I will try Blackwoods as there is one not far from me. I was toying with the idea of a solid piece of angle to mount on my crossbars at around 70 degrees so the Maxtrax would be on their sides so I have room for my basket also. I'm not sure if noise would be an issue...and unsure a) how thick the angle would need to be to support the maxtrax. b)how long the base of the angle would need to be that is fixed to the cross bar (probably long enough for 2 fixings?)2004 V6 Grande. BLACK -
