Sovereign bull bar fitting instructions
  • Uploaded to Rapidshare
    https://rapidshare.com/files/4600783...structions.pdf
    • Thanks for that Andrew.
      Wayne
      • No worries Wayne. Thought it might save you the hassle of emailing people... unless you are data mining and collecting email addresses to spam people ;-)
        I have a question for those who DIY install their Sovereign bar. I just bought a 2nd hand bar from Matt. He did not do the recall as he was changing to the ARB bar. The bar is now sitting at my parent's home in Castle Hill. I will be driving up there for Christmas.
        So I rang Castle Hill Toyota to enquire if I can bring the bar in the back of the Prado and have them perform the recall and install it at the same time for a minimal fee. They tell me that it takes 2.5 hours to install a bar and the nominal time to do the recall is 1hr. So the charge is $250-300. I thought that this was a bit steep and tried to negotiate the price down a bit but they wouldn't budge. I offered a case of beer but they didn't bite.
        They said that they have a special hoist for the recall where it holds onto the bar, disconnect from the vehicle, replace the brackets and reconnect to vehicle. This would certainly make things easier for them to perform the recall. However, they did say that if I brought the Prado in with the bar already installed, then it would be free of charge. I asked if all the fasteners gets renewed and the answer was yes.
        This got me thinking... if I can put on the bar myself just enough to drive 3km from the house to the dealer, would it be possible? I've read the instructions but currently don't have access to it.
        Are there any bits that need trimming?
        I know that the indicator/low beam light needs to be soldered onto the loom in the vehicle.
        Installing the chassis pin requires the radiator to be swung out. Is this difficult/time consuming?
        Is it worth me mucking around doing this or just pay them?
        • Hi Andrew
          Nothing needs realy to be trimmed, I managed to fit the inner guards without cutting and held them in place with a few screws into the plactic end part of the bar.
          I still havent wired up the indicators so I wouldnt worry about that.
          The radiator just needs the lower bolts removed and the top two loosened a little to push radiator back 20 mm to get chassis pins in, takes about 15 min to do that.
          takes about 40 min to remove the bumper there is a trick to get the plastic clips out on bumper where it meets just behind headlight.
          hardest part of install is holding bar up to front of car to get bolts done up but a few mates takes care of that, I used what is called a genie lifter to lift bar into position on my own,sort of like a two wheel trolley with a winch driven fork lift setup.
          all up took about 3 hours to fit up bar but if you arent to fussed about lining it up then may be done quicker.
          wayne
          • Thanks Wayne. That's very helpful indeed.
            I've got the overhead beams in the carport to hold the bar up. I've got dad to help me and maybe a Sydney Hills PP member [looks over at 1coolbanana ]
            I'll look at the indicator wiring once I get back to Adelaide. Hopefully it doesn't require the removal of the bar to get access to the loom !!
              T I've got dad to help me and maybe a Sydney Hills PP member [looks over at 1coolbanana ]
              No worries maaaaaaaaaaate
              • Cheers Marc. I'll be looking ever so jealously at your ARB bar.
                • Hi Folks,
                  I'm looking into fitting a second hand sovereign bar to my 120 and would appreciated a copy of the fitting instructions if someone has them to PM me.
                  Can I also use it as a check list to ensure all the fitting hardware is supplied?
                  Al
                  2015 D4D KAKADU
                  • alan. theres a bl**dy link to the bullbar instructions in this write up from amts....
                    do a bit of reading too so this doesnt clog up the forum with silly posts that have been answered.
                    [b][i][u]Toyota Landcruiser Prado 07' update Grande[/u][/i][/b]
                    Metallic Burgundy including upgrades (if you call these that here on pradopoint :P) for the avg. softroader.
                    Sovereign Bullbar with hella spotties.
                    Roofracks
                    Genuine rubber mats/cargo mat
                    Bonnet Protector
                    Hard wheel cover
                    Reverse Sensors
                    • Tried the link and it did not bl**dy work.
                      Hence my request!
                      Post Script: Now have copy via other source. Please disregard my request.
                      2015 D4D KAKADU
                      • The above link by AMTS doesnt appear to work now so this is a link to the file I placed on Myswag gallery.
                        LINK stopped working see two posts down.
                        At bottom of page in link there is another link to download file in original format, just click that and the PDF will open.
                        Wayne
                        sparksy
                        • Hi all as the links no longer work I was hoping someone could send me the PDF to rolf.hasse(no spam)@hotmail.com You will need to delete the (no spam) from the address.
                          Taken me 2 years to get to this point and now realise I am ready to install with a tigerz11 winch, have all the parts but no destructions to follow.
                          Rolf
                          • Sorry but when Myswag changed servers links changed also
                            new link
                            For the original Sovereign Bar Brackets
                            http://gallery.myswag.org/gallery/v/...geViewsIndex=1
                            Email sent Rolf, These instructions are for the original brackets not the new ones fitted on the recall. Just a hint dont cut any inner skirts untill bar is fitted and aligned up.
                            I found that following the instructions could lead to cutting off too much.
                            Any problems just ask.
                            sparksy
                            • I have the updated instructions which includes the recall brackets. Email sent Rolf.
                              • Got them. Thanks guys for your help :-)
