I have just been at the dealer and was about to get a toyota barrier installed when the service manager told me that the toyota barrier cannot be removed once installed. Has anyone experienced this? What about a Milford barrier instead or some other? How useable is the third row with a barrier installed? or is this advised against?
Can genuine cargo barrier be removed?
G'day Drummo and welcome to PradoPoint.
I have the genuine cargo barrier and it is removable. I wouldn't have purchased it otherwise. It's a bit of a bitch to get out but it's do-able. It can also be moved forward and re-attached so you can fold the seats up - very handy feature. For what it's worth my barrier is genuine Toyota Australia, made in Blacktown, NSW, and mine was purchased new with the car in January 2006.
Sounds like the service manager doesn't know his products very well, which wouldn't be all that surprising. I picked up some Toyota oil for my 120 the other day and the fella behind the spare counter came back with some of the oil for the older engines (thicker stuff). I said the engine is a VVT-i and that's not the right oil. He argued with me, his boss came out and fixed it up with the right oil. So it seems good technical knowledge isn't a prerequisite these days (as with most industries, been into Dick Smith lately?)
Drew.2005 Toyota LandCruiser GRJ120R Prado "Pilbara" (GX+) Petrol V6 5 Speed Auto, ARB AirLocker rear diff locker, Safari Snorkel, Bilstein Shocks, OME 2" Lifted Springs, PolyAir airbags, bash plates, Icom HF Transceiver, Uniden UHF CB, HID and LED lights, Black Duck seat covers, Tekonsha Prodigy trailer brake controller, Redarc Dual Battery Controller, ATS4X4 Side Steps/Rock Sliders.
Thanks Drew, yes it seemed a bit odd that it wasn't removeable. And yes i have had vague and sometimes incorrect advice from numerous dealers over the years! Does it anchor to existing points or is there any drilling required?2007 GX D4D Auto, 694s, Tint, Dual Batts, long ranger water tank, IPF Fatboys, Brown Davis bash plate, ScanGauge2, Safari Snorkel, Sovereign Bullbar, ARB lift kit
Originally posted by DrewSounds like the service manager doesn't know his products very well, which wouldn't be all that surprising. I picked up some Toyota oil for my 120 the other day and the fella behind the spare counter came back with some of the oil for the older engines (thicker stuff). I said the engine is a VVT-i and that's not the right oil. He argued with me, his boss came out and fixed it up with the right oil.
Imagine if you didn't know any better and stuffed up your engine (or at least created some dramas) just because some idiot should have known better.
This really riles me (if you hadn't already guessed) :evil: :evil:
Originally posted by DrummoDoes it anchor to existing points or is there any drilling required?
The top anchors to brackets that are bolted on behind the grab handles on the roof in four places so it can be moved forward, the bottom looks like it is drilled into the bodywork. To accommodate moving the barrier forward there are long extensions that fold up at the bottom. Does this make sense?
Thanks for the tip. yeah i have seen some threads on this too. I want the barrier for a central aus trip in the next couple of months but becasue the kids use the third row at the moment i want to be able to take it out and put it in just before the trip2007 GX D4D Auto, 694s, Tint, Dual Batts, long ranger water tank, IPF Fatboys, Brown Davis bash plate, ScanGauge2, Safari Snorkel, Sovereign Bullbar, ARB lift kit
Cargo barrier could be put in and taken out in 5 minutes flat...
The cargo barrier comes with fitting kit which get fitted to the car (mounting points) and it stays with the car (and not removable unless you
want to have holes in the car).
Toyota uses Milford cargo barrier with Toyota sticker on it . The
cargo barrier is fitted behind second row seats. You can't have
anyone on the third row seats while cargo barrier is installed (the are
a huge sticker on cargo barrier prohibiting doing so)...[color=blue][url=http://www.pradopoint.com/showthread.php?12128-2004-120-GXL-V6-Petrol-Buildup-*Warning-Picture-Heavy!*&highlight=picture+heavy][b]My Prado Buildiup Since 2004[/b][/url][/color]
[b]2004 120 GXL V6 4sp Auto D694 LTs and MTRs with Kevlar (best of both worlds )[/b]
[url=http://www.fuelly.com/driver/lc120man/prado][img]http://www.fuelly.com/smallsig-metric/48063.png[/img][/url]
Caddy Storage apparently make a cargo barrier that fits in two positions.
One behind second row and it then sits behind front when second row folded up.
Cost from memory just under $500.
Will be checking them out when I get my Prado.
Better give you the link
http://www.caddystorage.com.au/index...w=cat&catid=24
PedroPedro
2007 D4D Auto
Originally posted by PedroCaddy Storage apparently make a cargo barrier that fits in two positions.
Originally posted by DrewOriginally posted by PedroCaddy Storage apparently make a cargo barrier that fits in two positions.
Drew.
Toyota barriers are made by Milford (unless it changed since last year).[color=blue][url=http://www.pradopoint.com/showthread.php?12128-2004-120-GXL-V6-Petrol-Buildup-*Warning-Picture-Heavy!*&highlight=picture+heavy][b]My Prado Buildiup Since 2004[/b][/url][/color]
Originally posted by lc120_manToyota barriers are made by Milford (unless it changed since last year).
Oh well, I don't have any complaints about the barrier so far, it does the job I need it to.
So ignore all my ramblings on how the "genuine" barrier works because it appears mine might not be the same.
