For anyone that is interested I recently fitted a later model steering wheel with audio controls to my 2006 120. I researched at great length and finally got the controls working. The clock spring is the same throughout and the steering wheel cruise and audio wires plug straight in. There is no wiring however after the clock spring to the back of the stereo. I am including links that will show how to connect the wires to the clock spring plug. A PC CD cable will connect right up if you remove the pins and install them in the Toyota plug. I have an Android double din head unit and it works great with the steering wheel controls. My factory stereo had the socket for steering wheel controls so you could enable that with the later steering wheel also.
https://www.toyotanation.com/forum/1...-3-2011-a.html
https://www.newhilux.net/phpbb/viewtopic.php?t=24598
Hope that helps someone.
