DIY Sagging rear door fix
    On my to do list as well. Now to find a flat but of ground to do it on
      Just did mine thanks Mick - 90c for 2 x M12 SS Flat washers from Bunnings - Take that Mr Toyota!!!
        Did mine this arvo while waiting for the oil to drain. Can't believe I put up with it for so long for such a simple fix. Thanks again PP members
          I can just imagine all these PP'ers standing in their driveways opening and closing their fixed doors enjoying the solid "Thud"
          I still smirk every time I open or close mine. Best free fix ever.
          Mick
            Me too.
            Mick
            Terry
            Canberra
              Still all good guys? I've noticed more drop since I put the table on the inside of the door. Time to give this a shot.
              Blake
                Just fixed my 120 using Mick's advice - PERFECT! Cost $1 for washers and about 45 mins...
                Thanks Mick, terrific advice and pics.
                  This is on my list of things to do. From memory the Gregory's manual states that the door can be adjusted (can't remember if its the hinges or the latches)
                  What are benefits of this method vs adjusting the position of the hinges/latches?
                    98c later....
                    Blake
                      All done. Easy fix and only 25 min. Possibly a bit high but much better than it was. Used the zinc plated 1/2" washers
                      Blake
                        Just did the washer trick with my back door , couldnt get it in my head how it would line up any better but i was well chuffed when i closed my door, straight in no more banging ,
                        You guys are a fountain of knoledge.
                        Cheers Alan.
                          Hi,
                          i just done this fix.
                          Awsome !
                          • #28
                            What's wrong with just adjusting the door how its meant to be done? Loosen off the bolts that hold the hinge to the body and move it slightly. No dodgy washers required!
                            Travelling Panelbeater
                            • #29
                              Because they centre themselves in the hole.
                              Sent from my iPhone using Crapatalk
                              Blake
                              • #30
                                Not the ones I've had to adjust. Yes the hinge to door bolts are self centering bolts but not the hinge to body ones, and that's where you adjust it.
                                Unless the earlier 120s were different. Maybe Toyota changed them part way through the model. Pay to check before doing the washer thing, which although quick and easy, is a little dodgy(a shim would be better).
