Originally posted by woodwormm
View Post
Removing or leaving the door on is a two man job either way. If you do leave it on you could support the door then remove the stay and this will allow the door to go back just a little further. Its important to have someone hold the door so it does not swing back and make contact with the body. Access is not an issue, just use a ring spanner (single hex preferably).
I removed the door as I needed to take the hinges to the engineer shop but must say he had them ready same day.
When you put them back on just line them up with the paint marks (take your time) and there will be very little if any final adjustment once they are on. I got it almost spot on with just a little adjustment needed at the striker. I tension the bolts on the body.
Bolts are allen key head with nylock nut making them serviceable although they will see this vehicle out easily.
Merry Christmas
Hazza
