Scrub bars/ Front rails
    Ahhh thats cool ! I have seen a couple of those down this way, the first one I saw I had to go around the block and have another look I have also seen one on a 100 series and a couple of 70 series utes made by the same mob, I think they may be alloy though so weight isnt such an issue, I doubt it would be any more than a ARB steel bar.
    I doubt the footpath brigade would appreciate them in the city :shock:
      Guys,
      I'm taking my Prado into a place in Geelong in the next few weeks who are going to measure up and make a full set of side-rails and steps for me. We believe that we can gain maybe 1 1/2 inches of extra clearance between the ground and the steps.
      I will post photo's when i get them done.
      Mark
      '05 Prado GXL TD/Auto
      ARB bullbar
      12,000lb Ironman winch
      Brown Davis Bash Plate
      Ultimate Suspension
      Twin Hi-Clones
      DPChip
      Dual Batteries
      Safari Snorkel - Donaldson pre-cleaner
      Cooper ST's
      Outback Swan
        I've got access to a CNC mandrel bender at the moment (one that can do heavy wall tube) so if I can free up some time I might have a crack at the side rails myself.
        My only concern was the fact the big boys (ARB/TJM/OL) don't make them, I assumed there was a reason and I was thinking it might be the crumple zones.
        Mick
          I got the ATS side steps/sliders and they are great
          Dustie
            just saw the pic of the side bars and bullbar, and f$&k me thats ugly, you couldnt pay me to have that on my prado, i do understand it does protect the bodywork but is still ugly.
              no doubt about that matt.
                hmm... sounds interesting.
                2003 V6 GXL, Mickey Thompson MTZ's, Safari Snorkel, ARB Winch Bar, OME Suspension 2" lift, GME TX3420
                  It doesnt look any better in the flesh, sore it at 4x4 more in Brisbane waiting to be delivered, looked like it was sitting fairly low, definetly not designed for off road use due to the poor clearance at the front corners of the bar. Be great for touring in roo country, nearly indetructable
                  2007 D4D auto, Tunit Power Module, Scan GaugeII, Bilsteins & lovels HD, raised 50mm front & 60mm rear, 10,000lb Tmax winch, 7/16th Amsteelblue synthetic 23,000lb winch cable, TiTan HD winch solenoid pack, Outback draws with fridge slide & 50 litre Waeco, Ryno roof rack & Alloy Cage & extra set of Rhino HD Roof bars x 3, TJM type 15 steel Bullbar powder coated silver, Dual battery setup with custom tray, Bosch Navigator spots with 55w HID kit, Sand Grabber mats, Toyota Tow Bar, Sensor Touch Electric Brakes, Cooper ST 265/70/17 tyres, Uniden remote head UHF radio, Modified Milford Cargo Barrier, Extra power points in the back run with 10mm wire for fridge & inverter, Anderson plugs with 10mm wire front & back for the camper & compresor conections. 7 inch in dash JVC DVD player with bluetooth & Ipod adaptor, 39DB Stebel High Power TM80/2 Magnum Electric Horns. JL Audio 300/4, 300/2 power amps, Pioneer TS-C160R front splits & TS-D161S rear speakers & 12" Pioneer sub
                    Re: Scrub bars/ Front rails
                    In the last 6 months, it seems mining companies really like the full cow catcher/brush bar set up.
                    http://www.tuffbullbars.com.au/Prado.jpg
                    Most of the work-prados in western qld are now decked out this way, along with the 3m UHF aerials and std RM, ride-a-cowboy and Bundy stickers
                    You can feel the weight up front, the approach angle is worse than std (it hit going over a washout), but not to bad for most of the high speed dirt roads. Apparently there is not much more weight in the whole setup than an ARB bar with a 10 000 winch.
                    Kind a makes the sovereign bar look very metro-sexual :wink:
                    "Ooops I just deleted the internet, lucky I was able to recover 99.7% of it out of the bin" :lol:
                      i have got ARB cairns going to modify hilux brush bars and sliders. very similar...will be colour coated and look the goods..
                      will post pics when i get round to getting them fitted in the next month...
                      joey
                      -issue 52 Modified 4wds .
                        Sounds good Joey, something a little more useable off road should do the trick. There would be a few interested buyers
                        If everything is bolted straight into the chassis, with enough space btw the bars and the body work, it should all wobble together ??
                        Have you asked/looked into a bolt on replacement rear steel bumper bar with slider points, decent tow hooks and Hi lift jack points ?
                          havent got to the rear of the rig yet......
                          but i think it will be on the cards towards the end of the year...
                          i have to stop sinking money into the rig and divert it to the boat.....but its hard not to
                          joey
                          • #28
                            Good luck to ya Joey. I'll be interested to see the outcome.
                            I asked a Brisbane ARB store 6 months ago about the Brush Bars and Steel Side Steps for the PRADO.
                            Their response was that there probably wasn't enough enquiries for them which is why no product is available, only in Aluminium
                            I couldn't understand this as they had them for the Hilux and surely there would be little difference for the PRADO.
                            I was given the details for another 4WD Supplier who would probably fabricate a pair of steps/sliders for me.
                            Yikes.... that TUFFBAR from Spurio's post is F%^&! Ugly
                            If that Bar was my missus, I'd wanna wake up and chew my arm off.
                            Regards
                            Stewy
                            Stewy
                            • #29
                              i forgot to mention that they were going to be 1100 buckeroos as wwell..
                              the lads up here at ARB look after me and modified the 100 series arb half rack to fit my rig..
                              joey
                              • #30
                                Yeap, dumping that on a prado is kind a like sticking a beard and beer belly on Elle Macpherson (sorry bit out of data with the supermodels) :lol: :lol: :lol:
                                There must be a market out there though, I must have seen at least 100 of these just in Western Queensland !!
                                With all the doubled up barwork, I think the designer may have been inspired by Mad Max :lol:
                                PS - Some one else posted the link earlier in the thread
