new rear door design?
It looks quite feminine :roll:
2008 GXL M6 D4D, Silver
Build Up---> [url]http://www.pradopoint.com/viewtopic.php?t=2315[/url]
[b]{[/b]ATS Ridepro/Bilstein Lift[b]}[/b] [b]{[/b]Dual Batteries with RanOx Battery Booster[b]}[/b] [b]{[/b]600w Projecta 240v Inverter[b]}[/b] [b]{[/b]Dunlop AT3's / MT MTZ's on Speedy Grande Rims[b]}[/b] [b]{[/b]ARB Deluxe Winch Bar[b]}[/b] [b]{[/b]IPF900XS Spotties - Converted to 50w 4300k HID[b]}[/b] [b]{[/b]35w H4-3 4300k HID Hi-Lo Conversion[b]}[/b] [b]{[/b]ARB Underbonnet Compressor[b]}[/b] [b]{[/b]GME TX3440[b]}[/b] [b]{[/b]T-Max 10,000lb winch[b]}[/b] [b]{[/b]Safari Snorkel[b]}[/b] [b]{[/b]Milford Cargo Barrier[b]}[/b] [b]{[/b]Rhino HD Roofies & AT1410 Roof Tray[b]}[/b] [b]{[/b]60L Waeco[b]}[/b]
[img]http://www.gifs.net/Animation11/Transportation/Cars/4_wheel_drive.gif[/img]
so, back to my original question regarding the car I saw in Perth (which was not the photo - I found that on google) ... does anyone actually know if this is available in Australia, or is it as Leachy suggested, an import from NZ, or perhaps elsewhere?
btw, the one I saw did not have the wing mirror up front.
just interested - I like the tyre on the back (although I am convinced that the weight must add to the sagging) and couldn't bear to lose the 180L tanks
Same in Dubai
G'day mates
Same here in Dubai
This door configuration sells with the Grande
One will lose the spare fuel tank completely so 90 L and that's that
-whilst in the LC200 you still get 90+35L configuration-
The rear wheel is stuck underneath the car , access to is through a notch in above the rear door scuff plate where one uses a lever to rotate and drop the spare
Very awful if you are stuck in a muddy trap and you need a spare change
Also , less range for the car , and forget about the spare rim condition because of the shrapnels that keep hitting the light-alloy while driving off road. 8)
Only non serious 4W'lers will own this model here
CheersWhite VX LC120:2006
If you go to NZ Toyota website via link below, you can view their version of the Prado with new rear door (minus spare wheel). If you then check the specs for that vehicle, everything looks pretty much the same except the fuel tank is only 87L.
I don't care how the car looks with less than half the fuel tank capacity I would not consider it for Australian conditions!
http://www.toyota.co.nz/NewVehicles/Mod ... er%20Prado
From what I have heard, this is the design that conforms with current European design rules. They tell me they are not allowed to put a fuel tank behind the rear wheels in case the petrol explodes in an accident (which has never actually happened - especially with a diesel).2007 Prado GXL, Silver, D4D manual
ARB steel bar, HR tow bar, dual batteries, OME suspension w 50mm lift, BF Goodrich A/Ts, GME 3420, Twine shower and KK Classic CT
I agree with the fact that it is annoyingly small. I have a 2005 VX with the spare on the back and it still only has 87lt. Then again you can probably travel up & down the length and still have enough fuel for work on Monday :wink: :wink: :wink: :wink: :wink: :wink:Originally posted by NickIf you go to NZ Toyota website via link below, you can view their version of the Prado with new rear door (minus spare wheel). If you then check the specs for that vehicle, everything looks pretty much the same except the fuel tank is only 87L.
http://www.toyota.co.nz/NewVehicles/Mod ... er%20Prado2005 4.0 V6 Prado - Additions: Undercarrige Rubberised, 270 70R17 Cooper Discoverer ST, Wiper Jets Updraded, Rear Door Shelf, HID H4-4 Hi/Lo Upgrade, Prado Rubber Mats, Toyota Headlight Covers, New Gearbox (ouch),Diff & Gearbox breathers, Bypass Transmission cooler, Garmin Nuvi 760, Dual Headrest DVD Screen/Player combo for the kids, ARB Recovery Package, Bushranger X-Jack,
Re: new rear door design?
Looking at the brochure carefully here:
http://www.toyota.co.nz/NewVehicles/Mod ... ochure.htm
it is obvious the wheel-less rear door still opens sideways.
What a shame it doesn't open like a hatch....I was hoping perhaps the new 2010 Prado had a lift-up tailgate.
Sorry for ressurecting this but I saw one yesterday parked in the burbs of Sydney:
http://s405.photobucket.com/albums/pp13 ... age119.jpg
My guess is a kiwi personal import.'08 Prado Grande D4D Auto - [color=#800000]Flinders Red[/color], Piranha Dual Battery, GME 3440
If you run a roof rack basket or something similar Fishnut, you can store your wheel up there.
then you got the best of both worlds. :mrgreen:
