Rocker panel moulding
  • Rocker panel moulding
    Hi all hoping someone can help with part numbers?
    Chasing part numbers for the rocker panel moulding RHS (strip of plastic right above side step) and the clips and rubber strip to go with it. Local dealer want $80 just fpr the 16 clips! Cheers.
    Put your VIN into this site and browse to the body section, down the bottom of the screen will be the spoiler and side mudguard section. I think that is what you are referring to?
    http://www.japan-parts.eu/
      Ah cheers I will check it out. I did get all the part numbers and amayama is already $100 cheaper than the local dealer.
        Hi, I am facing this same problem and need to get replacement clips for the Rh Moulding, side skirt. I have a replacement moulding strip from wreckers and the sidestep too but I need new clips to attach the moulding back to the chassis. Where on this site do I input my VIN number?
        Thanks,
        Toney
          I can see the body section under Body/Chasiss 120 Series but cannot see the spoiler and side mudguard section.
            Sorted!
