This is constantly on now how do I fix this problem?
VSC/TRC BSC/OFF Warning Lights
egr plate fitted?HKB Electronics, manufacturer of the Alternator Voltage Booster, Silver 2008 D4D,Lifted,Underbody protection, Alternator Voltage Booster, Tiger Z winch, Lightforce DL, Air Horns, Tanami Drawers, Drop down fridge slide, Outback cargo barriers, Rotronics dual Battery system, Polaris GPS, HF/UHF/VHF, Radio speaker combiner, Long ranger water tank, Diff breathers, Inverter, Snorkel and others
You will need to plug in an ODBII scanner and read the diagnostic fault code to what triggerd the warning lights and reset. The comination of lights your getting can also be caused by an EGR flow issue so they can be missleading as to what the actual issue is.HKB Electronics, manufacturer of the Alternator Voltage Booster, Silver 2008 D4D,Lifted,Underbody protection, Alternator Voltage Booster, Tiger Z winch, Lightforce DL, Air Horns, Tanami Drawers, Drop down fridge slide, Outback cargo barriers, Rotronics dual Battery system, Polaris GPS, HF/UHF/VHF, Radio speaker combiner, Long ranger water tank, Diff breathers, Inverter, Snorkel and others
Originally posted by LeighW View PostYou will need to plug in an ODBII scanner and read the diagnostic fault code to what triggerd the warning lights and reset. The comination of lights your getting can also be caused by an EGR flow issue so they can be missleading as to what the actual issue is.
