Grille Mounting Tabs - Broken
  • Grille Mounting Tabs - Broken
    Well, after the Canning last year and the Simpson this year, 6 of the 7 plastic mounting tabs on my Prado grille have broken off. When I phoned a Toyota wrecker this morning he reckons he has 3 in stock but they all have broken mounting tabs. Looks like the tabs are not up to it. Has anyone else experienced this problem and if so did you try and fix or did you just buy a new grille (genuine is very pricey)?
    White 2012 GXL 150 TD Auto. Work in progress. Aiming to spend less than when I kitted out the 120!
    Re: Grille Mounting Tabs - Broken
    Ended up getting tabs plastic welded back on, so will have to wait until the next corrugated track to find out if the welds will hold. Welder reckons it was a bugger of a job as the tabs are so thin. In fact he had to weld them twice as the first attempt wasn't strong enough.
      Yeah I had two of mine broken off, I just used araldite to secure them
      Ades
