smaller front calipers for a 120 prado 06???
  • smaller front calipers for a 120 prado 06???
    can anyone tell me if u can get smaller brake calipers for the front of a 120 prado 06, or if anyones done this b4 help is needed.
    Why? To run 16" wheels? Not worth the trouble. Smaller brakes will probably render your car unroadworthy.
      no i have 17inch rims that are touching the caliber
        just wana know if u can or cant
          You can, but it's both illegal and dangerous so I won't tell you how.
          If your 17" rims are touching you likely have an unsuitable offset. I would suspect they are touching because you gave reduced the track, which if that is the case is also illegal and potentially dangerous.
          Best bet is to find suitable rims that don't touch.
            Yep yep
              Ditch the discs altogether, there's a couple of spares at the back end.
                its not the spokes of the rims that are touching, its actualy the inner diameter of the rim itself thats just touching
                  That could still be because of the offset.
                  Do you have any details on the rims, pictures, type, offset?
                    all the specs are right its just the way this rim has been made, its +25 offset , there called TUFF 7 rims from all wheels australia, prados are standard 30 offset
                      Are these a 9" wide wheel?
                        Grinder
                          yeah they are 9"
                            Well I think there is your problem.
                            Unfortunately I think you are going to have to look at changing rims, unless any rubbing is very minor and you can grind a bees dick of the caliper.
                              yeah ive grinded a bit ov them, unfortunately i took a beez dick too mutch on th left one, its lasted a few day but its now split under pressure lol, i thnk i might just get another caliber and not take as much ov this time. cheers for ur help andrew
