All,
Just some info for those not aware. I removed all my discs and hand them skimmed today. Fitted new Bendix 4wd pads and bled brakes. Had an issue with the front lhs caliper seizing up and causing brake drag and heat in the rotor. Once I stripped the caliper I found the lower outer brake piston seized up.
The new thicker pads obviously made the issue worse and more noticable. Found rust and shit in the piston bore in the small space between the outside of the bore and the inner piston seal. Sorted it with emery and assembled/bled the brake.
Seems fine now. Might be worth checking when servicing your truck next.
Guess it's nothing a year in the tropics, won't fix !
