Switched, I'd be more concerned about the cost of the extra fuel being used rather than wear on the tyres if the other half is accelerating that fast to stop them from unlocking.
4WD Systems Lokka
Trek, Yep the nails permanently fixed in the dash is a dead giveaway.
The Jeeeeeeeeeeeeeeeeesus bars get a workout too... its funny, I never knew how they got the name until i met the better half....[b]Silver 2008 D4D Auto GXL[/b]
G'day. I've just finished installing a lokka in the rear of my 95 series. I haven't had a chance to try it out yet - hopefully on the weekend! It was a reasonably large job but mostly because I followed the workshop manual most of the way before realising I didn't have to pull off half the things I had including pulling the handbrake assembly apart! Wasted hours there. Anyway the install went pretty smoothly except the internal clearances were too tight. After checking I had everything installed correctly a dozen times I called 4wdsystems. It turns out Toyota did a running change of the 90 series diff internals late 2001 early 2002. Mines a dec 2001 and I needed the later kit ( LR 124 not 123) so it was back to 4wdsystems to swap kits. I don't blame them - as far as we could tell you don't know which kit you need for sure until you have a look inside the carrier if you have a late 01 early 02 prado. Dave put the centre together whilst I was there and checked all the clearances which were spot on with the right parts.
I reckon I could do it in about 4 hrs start to finish now I know how few parts I really need to remove!
I'll post again once I've had a chance to try it out. Can't wait!
Sounds good mate, looking forward to hearing how it goes!Front and Rear ARB Air Lockers - Maxxis Bighorn 32inch M/Ts - Black 16x8 Sunrasias - Bilstein shocks - Lovells springs - Duel batteries - Ironman winch bar - Safari snorkel - Turbo timer - Boost guage - 3 inch mandrel bent exhaust - DP chip - Diff breathers - Custom Drawers - Towbar - Cargo barrier - HID spotties - Roof cage - Rear floodlight - Arb compressor - Garmin 1490T with Topos - 12000 Winch - Ozito chainsaw blah blah blah
Just went for a test drive on road to check the unlocking action. Works perfectly. Hanging my head out the window I could just hear the ticking noise on slow u turns but you really have to listen for it. The lokka disengages and re engages so smoothly I definitely couldn't feel it. It drives perfectly normally. Hopefully that all changes in the rough stuff when I'm lifting a wheel! Should definitely know it's there then
P.S. Sorry my last post was so long!
Guys tried to source one for my, after finally getting the ok from the boss, but they are now out of stock (for the LSD) and not making them any more not happy.
hope someone on here has heard different2005 120 Prado Pilbara Auto Diesel ARB bullbar snorkle Ultimate suspension 265 70 17 ORS draw system cargo barrier water tank PIAA 150 lights
soon MCC Rock sliders and Brush bars
Wish list HUGE
Originally posted by mpr7or View PostGuys tried to source one for my, after finally getting the ok from the boss, but they are now out of stock (for the LSD) and not making them any more not happy.
hope someone on here has heard different[b]Silver 2008 D4D Auto GXL[/b]
They still show the LSD Lokka for Prado's on their website and when I spoke to them last week they didn't say they weren't doing them any more.
Got to try mine out yesterday - all I can say is b****y brilliant. I knew it was working in several places on the track and being locked and lifted I felt confident everywhere we went. On one particular climb that had several deep ruts and washouts as it twisted up through some boulders the guy in front of me kept lifting (and spinning) one of his back wheels stopping his forward momentum (I think he was also lifting a front wheel at the same time). He had to go back and forward a few times to get through. I just drove slowly up with no loss of traction even though I'm told one of my back wheels also got plenty of air time. I certainly don't regret getting mine fitted.
Sounds excellent Barry.
I think that will be my next investment prior to a winch.
So in day to day use, you wouldnt even know it was there?Marc, 2003 Grande V6, Just a Bit of Stuff Done..........Work in progress.
Originally posted by 1coolbanana View PostSo in day to day use, you wouldnt even know it was there?
Originally posted by Trekrider View PostDay to day (on tarmac) the only time I notice it is the ticking noise when getting in and out of parking spaces and turning at junctions - i.e. slow tight turns. Even then it's not that loud unless you have the windows down and radio off.
Just get some mud tyres - then u won't hear the ticking!Front and Rear ARB Air Lockers - Maxxis Bighorn 32inch M/Ts - Black 16x8 Sunrasias - Bilstein shocks - Lovells springs - Duel batteries - Ironman winch bar - Safari snorkel - Turbo timer - Boost guage - 3 inch mandrel bent exhaust - DP chip - Diff breathers - Custom Drawers - Towbar - Cargo barrier - HID spotties - Roof cage - Rear floodlight - Arb compressor - Garmin 1490T with Topos - 12000 Winch - Ozito chainsaw blah blah blah
