Hi all
I'm hoping someone can shed some light on this one - it's taken be 24 hours to post (23 and a half of those hours spent searching PP to see if anyone had used one, several or any combination of these words in a post before :lol: )
Please enjoy the story - the ending is nothing without the adventure 8)
Went for a little picnic up in the Perth foothills. Gravel / dirt roads, a bit hilly, but nothing worth shifting the stubby lever for. Then we got to a short section with a large pothole, a couple of tree roots and a couple of approx 8" mud steps.
Went for the stubby lever and crawled up the steps - no dramas. Had a little slide towards the top and gave the front OEM bashplate another war wound. Popped the stubby lever back into H at the top and went to move off - but we were carrying a passenger. We had a stick up between the tranny and the exhaust - well, it wasn't even really a stick - more like a gang of teenage twigs pretending to be a stick. Removed it and kept going.
Got to a fairly flat muddy bit about 8 Kms further in and stopped to shift the stubby lever. Now I'm used to the little pic (looks a bit like this) ..
... but it didn't come on.
Tried shifting the lever in and out of lock - no indication that it had come on. Tried it with the auto in PARK or N, tried turning the car off then back on again, tried driving forward and backward a couple of times - no go.
Spent a pleasant 15 / 20 minutes crawling around in the mud - under the car - to see if I had dislodged something. Having a GXL means there's half a dozen spare GRANDE plugs on the wiring loom, still floating around in the space above the transfer case, and nothing looked like it had moved recently.
Stuff it - we packed it in and buggered off home (with the stubby lever in H). Once home I put it up on ramps and whipped both bash plates off (yeah - I know I didn't have to - I just felt like it), crawled around underneath and couldn't find where a plug may have been dislodged.
Took it for a drive around the block. Just before my place is quite a tight S bend. Put the stubby lever in HL and putted through at 20 - 25 km/hr with tyres squealing and protesting at being in 4WD on bitumen :shock:
So 4WD works (or at least the locking of the centre diff works) but the dash warning light doesn't.
Am I looking for a sensor, connector, wiring problem or could it be something as simple as a buggered dash light ?? ops: ops:
Now you can see the reason for the story. In the 6 mths I've owned the Prado, everytime I move the stubby lever, the light comes on. When I forget to put it back the light is there to remind me. At the beginning of the muddy bit it never occured that it may be a blown globe - press on.
So - has anyone had these dash light blow ? Is it a frequent thing ?
...or is it more llikely to be a connection somewhere ?
All guesses welcome.
... and YES Moderators ... feel free to flick this over to ELECTRICAL if it proves to be pissy little dash light problem.
Chippy
Chippy
