Diff locks
  • Diff locks
    Hi All,
    Got a price for a rear locker t'day, Opposite Lock quoted $1850 fitted, ARB quoted $2089 with their mid compressor & airline kit!
    Think I'll start saving for the E-Locker
    Steve J
    D4D 09 OME Suspension/ARB Winchbar/Safari Snorkel/IPF Spotties/Cooper ST Maxx Tyres/9000LB Tigerz11 Winch with Dynema Rope/GME Remote head UHF/Sheepskin Seat Covers.....Next on list Dual Battery Sys...In Dash GPS...Rear Diff Lock
    Originally posted by CaLLaN 52 View Post
    Hi All,
    Steve J
    Or do what I'm going to do & put a auto locker in the rear.
      What's the auto locker worth?
        Under $500, I'm about to sus it out more. D.i.y install.
          Is yours an auto?
            Originally posted by adrian5800 View Post
            Is yours an auto?
            5peed man.
              I'd be wary of fitting a lunch box locker in a manual. The suppliers I approached wouldn't supply one unless it was for an auto. Worth spending another $300 and getting a Detroit imo. Much more refined and because your replacing the whole hemisphere a whole lot stronger.
              Ades
                Ades
                Yes, I'm not sure why.... Any idea?
                  Gday, How does an auto locker work?
                  07 GXL 3.0L Diesel 6 speed manual,tough dog lift,polyaire bags. MTZ's .ARB bullbar,11lb winch,airtech snorkel,red arc dual battery system,custom drawers,shelves and cargo barrier,diff breathers,rear e-locker,arb fridge,msa drop slide,flat rack hi lift jack and shovel holder. roof top tent.fox wing awning with remote control led lighting,1600 led light bar,rear work lights,recovery points,on board compressor
                    Pretty sure its open until one side rotates past a certain angle and then it locks and stays locked while there is torque load. When you lift off it should open. Not sure it always works quite that reliably though.
                    [/CENTER]
                      so you'd lose momentum for a bit untill it kicks in i guess.
                        I had lock rights fitted f/r to my last toyota v6 5speed OK off road in places but disappointing on road...wet road and roundabouts it would engage disengage
                        making the car pig root or gas it to make it lock and around you go side ways out only had it less than three month..
                        Off road in sand was disappointing as well dig all 4 wheels in (off camber hill) take you over the edge where standard cars would drive.
                        Best thing now is I decide when to engage them ...IMO I would never have auto lockers again.
                        Geoff
                          Geoff
                          Thanks for the input Geoff,
                          Def going for the Rear E-Locker, ARB over $200 more & everyone I've talked to has had probs with seals leaking etc, but they due have a great after sales service, hope Opposite Lock/Harrop E-Lockers have same back-up.
                          Steve J
                            Love it when people post when they think they have half a clue. Wrong..
                            A simple google search on Wikipedia;
                            "Automatic lockers lock and unlock automatically with no direct input from the driver. Some automatic locking differential designs ensure that engine power is always transmitted to both wheels, regardless of traction conditions, and will "unlock" only when one wheel is required to spin faster than the other during cornering. These would be more correctly termed "automatic unlocking" differentials, since their at-rest position is locked. They will never allow either wheel to spin slower than the differential carrier or axle as a whole, but will permit a wheel to be over-driven faster than the carrier speed. The most common example of this type would be the famous "Detroit Locker," also known as the "Detroit No-Spin," which replaces the entire differential carrier assembly. Others, sometimes referred to as "lunchbox lockers," employ the stock differential carrier and replace only the internal spider gears and shafts with interlocking plates. Both types of automatic lockers will allow for a degree of differential wheel speed while turning corners in conditions of equal traction, but will otherwise lock both axle shafts together when traction conditions demand it."
                            http://en.wikipedia.org/wiki/Locking_differential#Automatic_lockers
                              Geoff
                              It works fine in my vehicle.
