Whine in low range
  • Whine in low range
    Hi all,
    Is it normal to have a whine in low range? I just purchased a 2008 prado 120 series and last weekend had it in low range for the first time. I noticed that it had a whine, my old subaru Forester did this also. I recently had the Auto transmission serviced and I mentioned it to them prior to service. They checked and replaced the oil in transfer case and told me that the oil was clean with no filings to be found. They told me that I would need to have the bearings replaced in the transfer case as they would be causing the whine. My question is if the bearings are worn shouldn't I hear the whine in both high and low range as I assume you use the same bearings in high range. When I asked my regular local mechanic he thought the same thing and said they might be trying to drum up extra business, they quoted me $2000 to replace the bearings in the transfer case. As this is my first "real" 4wd I don't know if it's normal to have a slight whine in low range. Obviously I would rather put that 2k to something else.
    Appreciate any help on this,
    Ben
    Its normal for low range to make a little more noise. You could describe it as a whine.
    Greg - 08 D4D Prado,
      I get a frequent whine from the LHS, not dependent upon low or high range though, more related to her wanting something I disagree with.
        Tell her to get out !! The whine is normal when in low range. .....cheers Steve
