Brand new GXL Automatic. Page 144 of manual. When I try to select LL from N on the 4 wheel drive lever it grates. Drive in N foot on brake as per instructions. Only way to select LL seems to be to switch off engine first. Anybody else found this?
Shifting to LL
Re: Shifting to LL
Hey everyone,
I am also experiencing something similar, but the other direction, when I go from LL back through N, I get a big gear clashing noise after going through N. Note this only happens when I am doing as the manual suggests, in neutral, foot on brake. If I move the transfer lever slowly, it clashes, but if I move it fast, no clashing.
If I put the car in park, I can then transfer in and out of LL and not experience any clashing, and I can move the transfer lever as slow as I want and no clashing.
Does anyone have an explanation for this ??
....further, I recently changed from an 05 to 06, and I couldn't change into LL in park in my 05, but can in my 06 !
Any thoughts ???
Best
Whitey2006 GXL petrol auto. ARB deluxe bar x3 HID IPF's, ARB alloy roofrack, ARB awning, BFG A/T, Safari snorkel, Piranha breathers, Pacemaker extractors, custom Ironman 45710FE 436-569mm with Dobinsons 350, custom Ironman 45682FE 383-618mm with Dobinsons 487, Firestone kevlar 60psi airbags, 30mm extended Roadsafe links, AMTS bashplate and recovery points, ABR Flyer with Powersonic AGM.
Re: Shifting to LL
I have 07 petrol and use "N" to change in and out of LL with no issues??[b]Rob[/b]
Re: Shifting to LL
To avoid I do it in two distinct step in a technique learnt with my old Disco - little stick move from H to neutral ( mid position ) rest there for half a second, the gently ease it in to L.
On the Disco I could move from H to L without coming to a complete stop, haven't been game to try that on the Prado yet.Cheers, Wayne
Re: Shifting to LL
Don't have a problem with my 08 model, just put it in nuetral and shift into LL or back
with no gear crunching at all.HKB Electronics, manufacturer of the Alternator Voltage Booster, Silver 2008 D4D,Lifted,Underbody protection, Alternator Voltage Booster, Tiger Z winch, Lightforce DL, Air Horns, Tanami Drawers, Drop down fridge slide, Outback cargo barriers, Rotronics dual Battery system, Polaris GPS, HF/UHF/VHF, Radio speaker combiner, Long ranger water tank, Diff breathers, Inverter, Snorkel and others
