Auto trans not finding the next gear.
  • Auto trans not finding the next gear.
    I have a Prado 120 auto 4D4. Over the last 80,000km this problem has happened 4 times. For no reason at the start of the day the transmission won't find the next gear so the motor rev's up then the transmission will then lock in, causing a loud bang and a surge forward. This has happened at 10,000 and 50,000 intervals. It only happens for a short time and all the dash warning lights come on, when that happens I know the problem has gone for another 10,000km or so. I reset the dash lights by disconnecting the battery.
    Hows your auto oil looking? If its rooted not that it should he at 80K but if it is the valve body wont circulate the fluid at cold correctly.. just a thought
      I should have mentioned that I've flushed and changed the oil twice, thinking that may help.
        Aha.. hmm thats different then.. im no auto specialist so id recommend taking that to a specialist getting them to have a look..might be something as simple as a valve spring has unseated or could be a rooted valve body.. did yiu use the correct oil?? And did u change the filter aswell?
          This has me stumped as well. Has happened on a couple of occasions as well, usually on cold running. Driving into a round-a-bout slowing to look and when clear accelerate and 'bang' into a gear. No lights or alarms then it goes away. I have changed my driving style to have a pause between lifting off brake to accelerator when cold.
          Only started after i flushed the tranny with toyota WS oil. Hasn't happened in over 20000 km now so maybe a sticky solenoid in the auto. Have recently done a 3 lt part change (had 4 lt in the shed) but not seen the problem for a while.
          What oil did you use for your flush? These boxes are fussy on the type of oil used.
          Rusty.
          To reset dash warning light you can use a scangauge or similar. Better than having to reset all the radio presets etc.
          Are you running a power up chip?
            Was the filter changed or removed and cleaned? Could be the filters blocked and the required oil flow is not being delivered.
              There are a couple of ATF fluids around that will work OK in these trannies... I used the NULON Multi-ATF (Full Synthetic). My local Transmission Specialist uses Atlantic Oil Full Synthetic ATF and it is 1/3 the price of the Mr Toyoda stuff.
              Sounds like a stuffed solenoid... or a piece of gunk that has one sticking.
              Stan Miko
              - 2007 120 Series 3.0L D4D
