clutch change experience in the 6 sp diesel
  • clutch change experience in the 6 sp diesel
    Hey guys
    for those of you that have had clutch issues from the factory clutch
    what are you opinions of the replaced clutch
    did it make it easier to drive with heavy loads ?
    or no difference
    was the pedal any heavier?
    did you opt for the HD clutch?
    what brand?
    has anyone tried the extreme clutch kit from Australian clutch in Adelaide ?
    we are now towing a 2T van, and when we first get going i notice a very little clutch shudder
    but as the car warms up that goes away
    i do rough the clutch up a little on the down shift to take the glazing off which helps
    but as it is still the std clutch i dont want to get caught out while away
    yesterday i had to take the van across town and the last stop included a quite steep stop at a set of lights
    all went well didnt slip the clutch or have any issues
    but i am gearing up to fit a new Heavy Duty one soon
    i was almost contemplating converting the car to an Auto , but i let the wife drive it with the van and she handled it very well so i will stick with the 6 speed
    (seemed like a lot of work anyway)
    Does that model have a dual mass flywheel? Anyone?
      Clutch shudder is a toyota thing. Nearly all the manual boxed landcruisers I've worked on/owned/driven have done it.
        Not to my knowledge
          i spoke at length today with the person that builds the pressure plates for the HD set up
          all they are doing is changing the casting which changes the fulcrum point to give it more clamp pressure
          the STD clutch from Aisin (supplied to the factory) has a clamp load of 980kg , the modified pressure plate has 1300kg
          but the trade off is when you slip the clutch it wear's more and wont last as long
          did any one find out if that guy in the states ended up making a repair sleeve for the snout
            It's weird, a mate put 80series clutch/manual box/transfer under an 80s Range Rover and it is the smoothest clutch he has ever driven.. He can reverse his camper trailer up his curved driveway without even a hint of shudder. V8, so maybe the engine is smoother.
