Bent rear axle
  • Bent rear axle
    Has any body else managed to damage an axle
    yesterday driving my 4 year old 120 series d4d I hit a wall (hidden by some vegetation) speed about 15 miles an hour, the wall was about 30cm high the back left wheel caught the wall. end on, the running board was bent down, when I got out the wheel was toeing out about 2 cm more than usual ,no tyre damage or wheel damage though.
    I managed to get it to our local dealer, it was handling like a greasy pig! and we put it up on the ramps and sure enough the axle had bent about 20cm in from the hub, So currently they are trying to find a new axle I hope they are a stock part in the UK.
    I had previously thought the thing was pretty indestructible, certainly compared to my previous Land Rovers.It has done 80000 miles without missing a beat Got to be a bit more careful I think.
    Hmmm... 2.2 tonne vehicle into solid object at just under 25 k/h.... :shock:
    I think you came away relatively unscathed.... head on would have been worse... Low wall into alloy sump/front diff/front suspension and you would have been walking home.
    Higher wall at 25 k/h head on = broken nose due to air bags....
    What factory, mass produced vehicle would have driven away from this un-damaged?
    Mick
      Mick
      H1 Hummer 8)
      2004 GXL V6 5 speed auto. Cooper STTs, 40mm Lift, Scanguage II, Flyer batterybox, GME3400 UHF, Engel 40L, Safari Snorkel, IPF Xeon Headlight upgrade, Milford Cargo Barrier.
      [img]http://users.on.net/matthewv/4wd/prado.jpg[/img]
        This has often proven itself...
        http://commandos.strategyplanet.gamespy ... erman.html
        Easter-08 White GXL D4D Auto - delivered in near record time (5d) from placement of order. Has turned into a "Bermuda" or "Swiss fund" where $ get lost or converted into mods/accessories.
          Mick
          i don't think many.
          good luck finding a new part in stock.
          did the axle bend or axle tube?
          most likely the axle.
          not a good find (rock).
          [url=http://www.fuelly.com/driver/damonat/prado][img]http://www.fuelly.com/smallsig-metric/50578.png[/img][/url]
            It was the axle that bent, the more i think about it ,it is quite impressive that it made it home
              You did what :shock: :shock:
              Top effort in testing the Prado's hardware to the limit however.
              So far I haven't had that issue and hopefully never will. It would probably be fairly rare I would presume also, although you never can tell. Maybe that is the weak spot in the car.
              Good luck with your repairs.
              07 Prado GXL, D4D manual, silver and a fridge with constantly changing beer levels.
