Castrol Multitrax is listed as 80w90 in my lube book.
difficulty selecting gears. 6spd manual
---------------------------------------------------------------------------------------------------------Originally posted by Davros View PostMy 120 has done 98000kms. I have changed the transmission fluid 3 times now and have only used Valvoline DURAGEAR 75W-90.
I don't have any of the problems described in this thread. I love the 6 speed box.
i have just had my clutch replaced in my 120 series .The gear box has just developed and hard to change 1st - 2nd gear(it improves when the boxs gets warm) .Previously i had also used Valvoline Duragear 75w-90 . i believe my mechanic has used what ever he had ??? .So i will be changing the oil this weekend- i hope this is the fix
Let us know if there is any improvement. If so ill be dropping the oil again![B]Prado 120 Series Build; [/B][U][url]http://www.pradopoint.com/showthread.php?24346-Desert-Dueler-120[/url][/U]
My 2 cents worth after having the gearbox removed twice with issues once by Toyota (who did nothing but change out bearings and still had the same issues) the second time I changed out the original box with less Km's on but asked to have Amsoil Servere Gear SAE 75W-90 synthetic extreme pressure lubricant put in. Can be hard to source but found a supplier now who has it readly available.Last edited by NZKIWIS; 27-04-2012, 03:53 PM.
Ok,
Just dropped the multitrax and replaced it with castrol syntec 75w-90. Will let you know if it helps the third gear syncro problem.
Cheers,[B]Prado 120 Series Build; [/B][U][url]http://www.pradopoint.com/showthread.php?24346-Desert-Dueler-120[/url][/U]
I Think the new oil did the trick. So far so good changing into third on cold starts. I wonder why Castrol does not list this oil in the lube book for the transmission?[B]Prado 120 Series Build; [/B][U][url]http://www.pradopoint.com/showthread.php?24346-Desert-Dueler-120[/url][/U]
