Is the transfer case and centre differential in the same case or two separate cases?
I found two large drain/fill plugs on the back of the transmission. The lube guide from caltex makes mention of two different oils, one for the 4wd diff and another for the transfer case.
Does anyone have a diagram showing the drain & fill points that they can post?
Any help would be appreciated.
Thanks.
Thanks.
