Transfer Case oil leak
    Geez it only cost $250 for one of the other members to have a leaky seal fixed on his front diff at a Gold Coast Toyota dealer, which to my mind would be harder to repair than the transfer case. maybe your guys were too busy and didn't want the work?
    Confidence - The feeling before you fully understand the situation
      OK Guys, I am in real bad position here. Went and bought the pars, drained the oil and now I cannot for the life of me get the drive shaft bolts undone. Is there a special trick to it?
      Andrew
      2005 VX Diesel - [URL="http://www.pradopoint.com/viewtopic.php?f=38&t=12823"]My Rig Buildup[/URL]
      [URL="http://www.fuelly.com/smallsig-metric/65233.png"][img]http://www.fuelly.com/smallsig-metric/65233.png[/URL][/img]
      [B]Bitumen - A blantant waste of taxpayers money![/B]
      [URL="http://www.pradopoint.com/viewtopic.php?f=38&t=12197&start=0&st=0&sk=t&sd=d"][/URL]
        If I remember right, the washer behind it was a keyed one. Is there a tab to flatten out before undoing the nut?
        Hope it helps
        [B]Cheers
        Bomber[/B]
        '07 Silver Ash GXL D4D manual, 2" lift (Ridepro Bilstiens), Polyairs, Colour coded ARB Deluxe Winch bar, Safari Snorkel, Toyota Tow Bar, Sandgrabba Mats, Michelle's Sacs seat covers, Rhino Aero Bars, Rola Vortex Roof Rack, ARB dual Batteries, 40L Engel
          Hi BlackVX
          the bolts in the drive shaft dont move they are pressed in only the nuts move.
          Hope that helps
            Hope it helps
            these are the 4 nuts holding the drive shaft to the flange, I can't see any tabs on those. I assume there is one on the the nut holding the flange on the transfer case, but I can't get at that one to look without removing the shaft from the flange first.
            The spanner goes on those 4 nuts without any issues I assume if there is a keyed washe with one side bent up I wouldnt be able to get the spanner on?
            Andrew
              Originally posted by Tazdevil View Post
              Hi BlackVX
              Hope that helps
              Yep those are the nuts I can't get undone, tried all 4. Even tried the dodgey method of hitting the spanner with a hammer and didnt budge.
              Andrew
                Just to clarify
                are you trying to move the bolts or the nuts
                  Just to clarify
                  just the nuts facing towards the front of the car, gold colour not the black side facing the back.
                  Andrew
                    hey BlackVX, I have just found the thread that explains very well with pics here
                    Hope this helps
                    [B]Cheers
                    Bomber[/B]
                      thanks mate, that is pretty much what I thought if only I could get those damn nuts off.
                      Andrew
                        Hey, I am out at Freeling I have a compressor and rattle gun if needed
                        [B]Cheers
                        Bomber[/B]
                          Thanks mate thats a great offer, I have given up tonight have another crack in the morning when I am a little less frustrated
                          Andrew
                          • #28
                            No problem. If it is too hard can look at it on the weekend. Busy Saturday morning otherwise free.
                            Good luck tomorrow
                            [B]Cheers
                            Bomber[/B]
                            • #29
                              well I finally got those nuts off, spoke to a friend of a friends mechanic and he told me - Put a ring spanner on the nut and then push the car forward, when the spanner hits the transfer case it should losen the nut. Well whadda ya know it worked, took a little more force than I was hoping.
                              Once I got those little buggers off no problems rest of the job finished within 30 minutes.
                              I tell you what though that seal was absolutely Fuc&^d due to the amount of mud in it.
                              Thanks everyone for the advise and especially for Bomber offering his compressor and rattle gun, much appreciated mate.
                              blackvx
                              Andrew
                              • #30
                                Thanks to this excellent forum, I will be changing my seeping seal myself too. When I first noticed it I gave Toyota a call out of interest for a quote to fix.... $260.00.
                                [b][color=#800040]2007 120 GXL D4D 6sp Man[/color][/b]
