Spool up
  • Spool up
    G'day
    I've got an 09 D4D auto and have noticed that there seems to be a bit of spool up of the transmission before it actually starts to drive after an over run condition . Typically this will be going down hill on no throttle , then when some throttle is applied the trans seems to spool up and then drive . I wonder if it's something to do with the trans holding a lower gear on a hill descent but then having a little think about it before actuallty driving again ?
    Any ideas ?
    Ross
    Re: Spool up
    I've got an 08 d4d. Mine does the same.
      Re: Spool up
      some autos will do this as the auto thinks about what gear it should be in. Most noticeably occurs in the scenario you said due to the sudden change in speed/momentum and throttle input. dpends on the auto transmission and manufacturer etc.
      [size=2][color=#00BF40][b]2003 120 GXL V6 auto[/b]. GME TX3440 and AE4703, Mickey Thompson ATZ 4 rib LT265/70R17 plus roadies, Ausguard cargo barrier, BD bash plate, OME lift with Sport shocks. And hopefully more to come, slowly slowly...[/color][/size]
