Knocking sound whilst turning
  • Knocking sound whilst turning
    Hi guys,
    I've asked this question before thinking it might be noisy bullbar, however I am now convinced it has something to do with the drivetrain.
    Whilst turning left or right (full lock) a slight, barely audible knocking sound can be heard. The quicker the wheels turn, the more frequent the knock. It's so slight that if you have your radio on, you will not hear it. It sounds slightly as if I locked the centre diff and proceeded to do some turns on a hard surface...similar but lot less audible.
    I'm thinking it's just the toyota drivetrain as the sound seems to be coming from the front (front diff? maybe transfer case which is underneath the driver). What's your opinions?
    Re: Knocking sound whilst turning
    Possibly CV joints on their way out??? Full lock will put the most strain on em...
    Chriso
    [COLOR=blue]Current rig - 150 GXL D4D Auto TJM bullbar. Airtec Snorkel. ARB Underbonnet Comp.
    Previous rig - 02 TD GXL.[/COLOR]
      Chriso
      I thought about it but the cars only done 30k kms!!! also CVs normally sound noisier when the accelerator is pushed down and this doesnt happend (or maybe it does but the d4d wins the noise battle?)
        Originally posted by pjorek
        Hi guys,
        What size tyres and wheels are you running? I had the same problem and it was my MTZ's rubbing the upper control arms... only in reverse though. I've since changed my rims to +10 offset which solved the problem.
        Double_D
        [b]2006 GXL Prado 1GR-FE [/b]- ARB Lockers & Bar, Tigerz11 Winch, snorkle, Custom Bash Gaurd & Steps, AJ4x4 Rear Bar, Spotties, UHF, Dual batt, 33" KM2s, Custom drawers, Ext Icon Coilovers, 4" SRC Shockies, Dobinson 4" Springs, Diff drop, Light Racing UCA's, Ext SS brake lines, Driveshaft spacer, Superior trailing arms, Nitro 4.56 diff gears, DBA Slotted brakes, TRD Supercharger, Bullet Ultimate Exhaust, XEDE Dual map Processor
          standard tyres + rims
            Good excuse anyway to get new tyres and rims :mrgreen:
            If it's still under warranty Toyota will fix for free
              Try greasing your steering stops.... When dry they are a very common source of noise at full lock.
              Mick
                Maybe a thought but try the lopwer control arm bushes. I have a knock coming from the front, got it checked out and was told lower left control arm bush stuffed which gives movement (the knocking sound).
                Worth a look.
                2004 GX TD Manual. Mods include: Roll cage/cargo barrier, snorkel, ECB Bull bar, side steps & tow bar. Future mods: Lift kit, GXL rims, roof racks, draws etc etc.
                  cheers guys, dropped it off to Rob at Robson brothers for a 30k service and asked to have a look at it, will update you what it is. I reckon MickL might be on the money here...
                    Originally posted by MickL
                    Try greasing your steering stops.... When dry they are a very common source of noise at full lock Mick
                    That was the corrective action I did for this fault (knock sound at full lock); seems to be a common one esp after a few water crossings.
                    2014 Toyota Prado 150 D4D Auto (facelift); ARB Deluxe Bullbar; OME 2" Lift; Rhino Pioneer Platform Rack; Redarc BCDC 1225 with Optima Yellow Top; BF Goodrich Mud Terrain KM2; Lightforce Genuine Custom 70w HID; GME UHF; Safari Snorkel; Rigid Industry SR-Q2 side lights (yet to be installed); Domin8or winch (yet to be installed)
                      I had a similar problem with a Ford Fairlane. It was traced to sticking clutch plates in the limited slip diff. Cure? Change diff oil an d do slow speed circles in opposite directions to lubricate the plates. I now do regular circles in all vehicles I own with LCD'S
                      Monty
                      Monty Landcruiser LC200.D4D.
                        Monty
