Originally posted by Bushbasher
View Post
Toyota WS Fluid Servicing and Longevity
Fine meshDave
It's on the drivers side, about half way up , from memory it is 24mm and has WS marked on it.Originally posted by thebigo View PostAnyone got a picture and diagram of the plugs on the gearbox that need to be removed? Obviously can see the ones on the pan but which ones on the side.1997 petrol auto, 430 000km. Still going strong.
I second this.Originally posted by stanmiko View PostNot putting a new filter in your auto when doing a flush and refill with fresh oil would be like doing an engine oil change and not replacing the oil filter. If you're there doing it, do it right the first time - it will be worth it in the end.
If you've done a lot of hard km's on your auto, don't just flush it, replace the pickup screen.
There is at least one driver on fjcc (FJ runs the same auto) who burnt his oil and clogged the pickup screen with broken down colloidal muck, and starved the torque converter. $3000 replacement.
The pickup screens are cheap from Repco, you can even get oem through Dubai Amayama for around $50. Toyota parts in Australia will charge you around $200 for the pickup screen and the filter.
Penrite advise not to get WS or LV over 100C. If you're hitting those temperatures, you'll need to consider a larger cooler.
Best
I've ordered a Ryco transmission filter kit (Part No. RTK 138) from SCA and planning to have a crack at the transmission in the coming weeks.
What torque are each of the nuts meant to be tightened to?
Should I use a sealant when replacing the transmission gasket? If so, what's the recommended sealant?
Cheers in advance!11/2007 Prado GXL D4D Auto [B]BLACK [/B]Stock Option 1.
If you meant the oil pan bolts then they should just be tight and snug. Ideally with a 1/4" ratchet and a 10mm. As for the gasket, Toyota doesn't use sealant so why should we. I wouldn't either. Just use what comes in the package.Originally posted by Lycaon View PostI've ordered a Ryco transmission filter kit (Part No. RTK 13 from SCA and planning to have a crack at the transmission in the coming weeks.
Cheers in advance![B]CANYONEROOOOO *whipping in the distance*
Hey,Originally posted by Lycaon View PostI've ordered a Ryco transmission filter kit (Part No. RTK 138) from SCA and planning to have a crack at the transmission in the coming weeks.
Cheers in advance!
I only just saw this so a slow reply, but....
Be extra careful with the pan bolts, they can easily be seized. Their torque is only 4.4Nm, note the decimal point!
You can't use sealant down there, the ATF will eat away at it, use the genuine Toyota gasket!
Best
Thanks all. I ended up paying a professional to flush the ATF, replace filter and gasket - first time the AT has been serviced on this vehicle (Nov '07 D4D, 180k). As a bonus the ATF service appears to have mostly resolved a torque converter shudder at low rpm (light throttle) in 4th and 5th gear.11/2007 Prado GXL D4D Auto [B]BLACK [/B]Stock Option 1.
Great to hear it solved the issues.Originally posted by Lycaon View PostThanks all. I ended up paying a professional to flush the ATF, replace filter and gasket - first time the AT has been serviced on this vehicle (Nov '07 D4D, 180k). As a bonus the ATF service appears to have mostly resolved a torque converter shudder at low rpm (light throttle) in 4th and 5th gear.
Can I ask roughly what you paid for this. Toyota (in Perth) have quoted $380ish I think was the price when I last rang them for a flush only (that included oil).[B][2007 GXL 120 3.0L D4[COLOR="#FF0000"]D[/COLOR] Auto][/B] [I]Mods:[/I] [COLOR="#DAA520"]Bilstein [/COLOR][COLOR="#0000FF"]Shocks [/COLOR]& [COLOR="#DAA520"]King [/COLOR]2" Lift Springs - 265/70/17 [COLOR="#3366ff"]Cooper [/COLOR]AT/3s Tyres - [COLOR="#FF0000"]ARB [/COLOR]Deluxe bullbar - LED Spotlights & Worklights - Snorkel - [COLOR="#008000"]BushSkinz [/COLOR]bash plates - 2.2m Alloy Overlander Full Rack - 2.5m [COLOR="#8B4513"]Wanderer [/COLOR]Awning - [COLOR="#FF0000"]GME [/COLOR]TX3120S UHF & [COLOR="#FF0000"]GME [/COLOR]AE4703 6.6dBi - [COLOR="#FF8C00"]Milford [/COLOR]Cargo Barrier - [COLOR="#FF0000"]JVC [/COLOR]indash DVD - [COLOR="#FF8C00"]Maxtrax [/COLOR]- Pulling a heavily modified [COLOR="#3366ff"]Jayco [/COLOR]Dove Pop Top Camper
Cheers mate. Guessing not at Toyota and using Penrite?Originally posted by Lycaon View PostAll up it cost me $500 inc gst - 2.3hours labour, 11L AT fluid plus the ryco AT filter kit.[B][2007 GXL 120 3.0L D4[COLOR="#FF0000"]D[/COLOR] Auto][/B] [I]Mods:[/I] [COLOR="#DAA520"]Bilstein [/COLOR][COLOR="#0000FF"]Shocks [/COLOR]& [COLOR="#DAA520"]King [/COLOR]2" Lift Springs - 265/70/17 [COLOR="#3366ff"]Cooper [/COLOR]AT/3s Tyres - [COLOR="#FF0000"]ARB [/COLOR]Deluxe bullbar - LED Spotlights & Worklights - Snorkel - [COLOR="#008000"]BushSkinz [/COLOR]bash plates - 2.2m Alloy Overlander Full Rack - 2.5m [COLOR="#8B4513"]Wanderer [/COLOR]Awning - [COLOR="#FF0000"]GME [/COLOR]TX3120S UHF & [COLOR="#FF0000"]GME [/COLOR]AE4703 6.6dBi - [COLOR="#FF8C00"]Milford [/COLOR]Cargo Barrier - [COLOR="#FF0000"]JVC [/COLOR]indash DVD - [COLOR="#FF8C00"]Maxtrax [/COLOR]- Pulling a heavily modified [COLOR="#3366ff"]Jayco [/COLOR]Dove Pop Top Camper
Whitey
