Clunking noise while reversing
  • Clunking noise while reversing
    Sadly, our Manual 120 has developed a clunking sound while reversing. Yesterday it was apparently fine, but this morning as I was reversing out of the garage I heard this dreaded sound.
    It increases in tempo the faster the car is travelling (in reverse). Going forwards there is no noise. Changing gears is normal, it's just when the car moves. In reverse, with the clutch in, there is no noise when the car is stationary. When in reverse moving backward is when the noise is heard (both clutch in and out).
    In first, with the clutch in, rolling backwards, there is no sound.
    Looking at the driveline, all looks normal to me. There's no play in any of the drive shafts.
    Any ideas gurus?
    :? :cry:
    2003 GXL V6
    Safari snorkel
    Re: Clunking noise while reversing
    There are a lot of posts about this issue already. There are two possibilities from memory. One is that the car has been wet and the bang is the brake calipers releasing while the other is to do with the tailshaft and I believe Toyota just apply a shit load of grease to resolve.
    [COLOR=#000080]Nick[/COLOR]
      If it is only when the car is moving backwards, could be brake pad wear indicators?
        The noise is only apparent when the reverse gear is selected. If the car is rolling backwards, in any gear but reverse, there is no noise.
        I have done a search on PradoPoint, and using Google, and the symptoms indicated in the other partially related threads are different.
        I have taken the car to a few places and have spoken to a few mechanically minded friends, and it's sounding like a busted tooth on the reverse gear, or a bearing problem. I've had the gearbox oil flushed this morning, and no tooth came out, but there were fine metal particles in the oil.
        2003 GXL V6
        Safari snorkel
          It was a cracked tooth on the reverse gear.
          Got the gear cluster replaced, a new heavy duty clutch and all the appropriate jobs done while the transmission was out.
          2003 GXL V6
          Safari snorkel
            sorry to drag up an old post, but mine is doing the same thing this morning. Was fine yesterday and now has a clonk noise in reveres when the clutch is out. The noise changes with speed. When rolling backwards with the clutch in it makes no noise. Bunsen, how much did the replacement of the gear cluster cost you?
            Scott
              Check your Uni joints as well. When not under load they wont make much noise, load them up and they will. Cheaper the check them than pull apart the gearbox.
              If you do end up replacing them, put in greasable uni's
                The uni joints on the 120 kzj have 4 grease nipples plus 1 more per tail shaft slide.....
                John
                  Thanks for the replies. I have greased the two nipples on each end of both tail shafts but missed the one on the slides. Will have a look tomorrow. I understand how loading up the joints will make noises but I am a little confused why if uni joints, why they only make noise in reverse?
                  Scott
                  Edit...........
                  I have just gone out to have a look at the car, I greased a nipple on each end of each tail shaft plus a slider. Mine doesn't seem to have any more that I can see.
                    I found the culprit of the reversing noise yesterday (well Toyota did). The reverse gear was buggered but other internal gear box parts. The result is a gear box rebuild. I am not sure on the cause of the damage but a bit pleased it happened now and not in 3 weeks time on the way to or at cape york. Thanks for the replies.
                    Scott
                      Apologies for not replying sooner. I'm not on the forum much these days. Scott, I'm glad you found the cause of the issue. I was told that a primary cause of the cracked tooth was putting the tranny into reverse while still rolling forward. I can't for the life of me remember doing this, but the missus was a bit sheepish when I asked her!
                      My next drama is either a buggered throwout bearing, or rattling clutch fork? I can't say I've enjoyed the experience of having a manual?
                      2003 GXL V6
                      Safari snorkel
                        I echo your sentiments regarding having a manual. My vehicle slips out of reverse gear but only when reversing up a steep hill… just wondering if it could be a broken cluster too? How much did yours cost to rebuild or did you install a reconditioned gearbox?
                        I also have problems with my thrust plate bearing. There is another post on this forum which talks at great length about a defect with the Toyota cover sleeve which keeps failing…
                        Bryan
                        02/07 Prado GXL D4D 6 sp manual bought Oct 2009 with 43k on the clock. ARB bullbar and Redarc dual battery system, safari snorkel, 2" OME lift, front ARB air locker, Cooper Discover S/T Maxx LT265/70R17s, 17" black CSA steelies, GME TX3520 80 ch UHF, Dept of Interior rear roller drawers, full length Rhino-Rack and Sunseeker side awning.
