Cannot select Low range
  • Cannot select Low range
    Hi All
    I am New to Toyota after having 2 nissans and a mitsubishi.
    I have just bought a 07 d4d prado manual and cannot select low range,
    I have tried in and out of gear, engine off and on, reversing and forward,
    Have tried spinning tyres in the sand etc
    Please Note i do not have an owners manual yet so theres no "last resort"
    Need help ASAP
    cheers Pickles
    Re: Cannot select Low range Need help ASAP
    is it auto or manual gearbox
      Sorry Forgot to add its a 6sp manual
        well thats a curly 1, where did you buy the car from private or car yard
          Auction buy
          Was ex Dept of Ag with full service history
          Will keep posted of result, Bugger is it is loaded now to head to esperance tomorrow fishing, Hopefully i don't need low
            So what happens when you try? does the little stick move or not?
            Mick
              I have something similar in my auto, must be in "Park" to be able to get it in or out of RL. Never heard of it in a manual .... does it grind when you try it and does the stick feel firm?
              Bazza.
                Stick is jammed solid near on no movement at all apart from a bit of flex in the stick, It is a manual so its not the Park or Neutral situation,
                I have spoken to a mate a toyota mech and he said likely to be selectors are jammed up
                Fingers crossed that all it is, Other wise he said there is a bush that wears out or lets go.
                Booked in For 11am
                  HI all
                  Well here's the problem, the vehicle has previously (prior to me) had a new clutch fitted,
                  when they reassembled they managed to not insert the 4wd stick into the socket and was jammed in beside
                  therefore it wouldn't move out of high.
                  I was going to remove the rubber boot myself last night but opted to take it in to toyota
                  The guys at Galleria Toyota in Morley had it sorted in about 30min tops and cost $50
                  can't complain about the service.
                  Now off to catch a big Fish down south
                  Cheers pickles
                    No wonder it was jammed! :shock:
                    Good result though.
                    Richard
                    2011 GXL TD Auto Prado Silver
                      Originally posted by pickled
                      HI all
                      Cheers pickles
                      No fish left near Esperance - all gone unless you can get out to sea a bit. Oh, you might get a salmon (cat food).
