Hi, I have had a thermostat fail after 8 months and the installer seems to think that there may be an electrical current going through the cooling system which caused white scale on the thermostat and may have caused it to fail. I can understand the white scale (maybe) but not how it affects the thermostat.
He also said the current, if present, will corrode the radiator.
Is this reasonable? If so, where is the electrical current coming from?
I think he didn't replace the thermostat! Can I check the serial number to see if it was OME?
Sorry about the double barrel questions.
Bill
Bill
