Dual Battery Monitor
    Yeh, ABR has some very well priced stuff but their monitor is the wrong size for me. Derek has saved me some dollars on other item.
    Gotta be some other alternatives........
      someone here on PP had posted up a pic of there unit sitting up on top of the steering column. was rectangular not very high and looked the goods to me. would have pursued one if i didnt get the abr one. cant remember who, where, when etc it was here on pp
      [size=1][color=#990000][b]--> Macarthur District 4WD Club Member <--[/b][/color]
      ::2005 Black Grande Petrol V6::2 x PP Stickers::ARB Deluxe Winch Bar::IPF Spotties + Fogs:: Dual Battery, ABR DBi120 Isolator & Volt Monitor::ARB Portable Air:: Rear Drawer Unit::Trek Table::WAECO 40Lt::WAECO Raps R12U::AMTS Rear Tyre Spacer::HILUX Washers::UHF::Prodigy P3::Stebel Air Horns:: Inverter::CouplerTec Electronic Rustproofing::OEM Roof Racks, Towbar, Hard Wheel Cover::REAR CAMERA to factory GPS::[/size]
        Mick, was it something like this:
        Jaycar (and probably other electronics stores) sell these things. There are different options available and they are about $40-$50. The one in the image above has voltage (sin gle battery only) plus temp in and out plus clock for about $45.00. http://www.jaycar.com.au/productView...e&form=KEYWORD
        Here is another from Jaycar:
        http://www.jaycar.com.au/productView...r&form=KEYWORD
        This one covers volts (single battery) plus clock and stop watch. Cost is about $40.
        [COLOR=#000080]Nick[/COLOR]
          something like those ones. i thought it was able to switch between 2 batteries, but it was a quite awhile ago that i seen it. i cant remember who had it
            National Luna also have some offerings - too big for what you want MLC, but I thought I would chuck their name out there for others.
              I'll second madkore with the luna unit, only down side is trying to see it during daytime (postion most likely) plus its size is to big for your requirements
              2008 GX turbo diesel auto 5sp Fitted: snorkel dual battery kit kaymar twin wheel carrier Evenutally fitted: Bullbar VHF & UHF radios, storage system Still to come: winning lotto number to pay the blessed thing off set of decent side steps/rock sliders
              Too many projects so little time and even less money
                Solved my dual battery monitor problem! Picked up an LCD monitor that shows voltage as per the picture. Will rig up an On-Off_On switch and hey presto, dual battery voltage meter.
                Just have to rig it up.
                  That looks good I bought the piranha one and had it secured (well sort of) with double sided tape, but kept coming off, so I used the same blank plug as you groves out a slot for the cable and glued it to the blank with hot melt glue. I would of preferred your option if I had thought of it.
                  ...If its not on all 4's it's not on.....
                  2008 GXL D4D, OME lift, arb bar, IPF 55W HIDs, HID headlights, duel Batteries, Winch, UHF, Safari Snorkel, bfg km2's, arb side awning, rola cage, engel fridge, kaymar rear bar(to fit)
                    I've got an ABR one in mine. I've attached it to the centre console with double sided tape. Does the job and has the link batter switch.
                    Jaycar have an adjustable voltage monitor/cutout device that is good for 20A with a heat sink and 10A without. These can be wired to a power relay to make a power cut out device. If a relay with enough contacts is used, a buzzer can be wired to a spare contact for an alarm.
                      Looks a bit oldfashion and doesnt have all the bells and whistles but might just do the trick:
                      http://www.biasboating.com.au/p-473-...on-tester.aspx
                      cheers
                        Pretty keen on this jobbie... Price seems a bit steep though, will look around and see if there are any cheaper suppliers around..
                        http://cgi.ebay.com.au/ws/eBayISAPI....=STRK:MEWNX:IT
                          Mitch. I have one of the inserts and use a on-off-on switch (carling switch). This means no bulgy sticking out bits. I like my final result per my rig build, just need to connect it up.
                          • #28
                            my uhf radio includes volt meter (on the hand piece) and since it's hooked up to the 2nd batt it also monitor it...just a thought for some of you who would like to save some $
                            • #29
                              Pjorek, what type and model UHF?
                              • #30
                                gme tx3340, one with the remote mic keys, however i'm pretty sure other models would have it too. As a default option the radio displays signal strength when receiving (talking to someone) however i changed it to monitor my 2nd batt (quite easy to swap to signal strength whilst talking anyway)
